S14 SR ECU Problems, Need som Advice....
look ma , no hands!
on
Car is not starting ( although Cranking), Its not even trying to start,no sputter just the starter is cranking it over. This all came about 2 days ago rather random, The car was running fine and Now it will not start.
I have done the following
Checked for Spark---OK
Checked for Fuel ----OK ( Spark Plugs are Drenched in fuel if i pull coils and Try and start)
Checked all fuses ---OK
ECU-- NO LED LIGHT ON BACK
I started with the S14/200sx FSM and did the following Checks,
Checked power at pin 49-59, --- Battery Voltage
Checked Pins 10,20,107,108,115 for contiunity , ---- OK
Then It says check connections---- They are all on firm\
Not sure were to go from here. I searched but found nothing specific on this type of problem , Any Nissan Wiring GURU's out there have any advice.
Top speed is nothing .... Acceleration , now thats a thrill!
look ma , no hands!
on
I have tried to also spray a Starting fluid down in the Trottle Body to see if it tries to sputter or anything and NOTHING, I would think with FUEL and SPARK it would at least sputter and not just crank on the starters power alone.....IM STUMPED.!
