weird clutch problems
Old Jan 31, 2005 | 08:25 PM
Philly Blunt's Avatar
TR Balla Donor Supreme
Default weird clutch problems
Ok, my clutch is strange, when i get up in the morning to start my car i push in the clutch it will stay on the floor i have to reach my toe underneath it and pull it back out and pump it a few times to build pressure. and it always feels like it never engages fully and my clutch release is right on the floor. do i just bleed it to change the release position? does it sound like i have air in the lines?
Old Feb 1, 2005 | 06:28 AM
any suggestions? hmmm im gonna try to bleed it today and see what happens
Old Feb 1, 2005 | 07:46 AM
Jonas's Avatar
bleed it, play with the adjustment, and if those dont work... get a new slave cylinder.... if that doesnt work, get a new master cylinder... also in the process get rid of that second bleeder.
Jonas
Old Feb 1, 2005 | 09:16 AM
Matt Vassallo's Avatar
lifelong learner
yeah sounds like you have a leak. new clutch master cylinder, new clutch slave cylinder. if you want to firm up the feel of your clutch for performance driving, look into a braided clutch line that eliminates the clutch damper, and if a peformance clutch is in the future, the nismo slave cylinder is a larger diameter, and uses a pretty unique internal design. for many a stock clutch slave cylinder is enough, however. the twins run nismo slave cylinders with nismo braided clutch lines.
rest in peace tim.
Old Feb 1, 2005 | 12:54 PM
cyanide's Avatar
i read on freshalloy a while back that the nismo slave cylinder is the exact same part as an OEM N/A Z31 slave cylinder. it costs $40 from courtesyparts whereas the nismo is like $180
Old Feb 1, 2005 | 01:22 PM
lifelong learner
I was the one that posted that origionally, and I was wrong. external dimensions are the same, but the rest is different. Also the Nismo comes with a strenghthened pivot which has been known to fail.
rest in peace tim.
