S13 KA24DE Turns But Will Not Start
Old Jan 15, 2005 | 10:43 PM
VoidDweller's Avatar
TR Balla Donor Supreme
Thanks! I'll check around to see what I can find.
Old Jan 23, 2005 | 05:36 PM
Originally posted by TNathe
if it is the head gasket it will cost you 100 bucks plus your labor or more money for someone elses. for 300 bucks you can easily find an s14 ka to put in your ride or an older engine for less. Then use your current motor to slowly build up a badass powerplant as you get the resources to do so. That would be the way I would go.
More cost effective than SR? No, but the same is vice versa. All depends on what YOU like more, truck power or pussy car power. haha.
I'm thinking this is probably the way to go.
If you wouldn't mind pointing me in the direction of a good source for a used KA, I would really appreciate it.
Is the S14 is a direct bolt on for the S13 (ECU, wiring, emissions, trans, etc...?)
What would you recommend I start rebuilding first on the KA to get around 300 whp?
Thanks!!!
