Injectors wont fire on SR
Hey guys, i need some help. The swap is done but the injectors wont fire. It has fuel pressure and spark but the injectors wont fire. I am thinking that this could be wiring, ecu, or maybe cam angle sensor not sending signal? I would appreciate some help....
All opinions are welcome.....
Thanx
Norlandt
Thanx
Norlandt
http://inductionperformance.com/
Induction Performance - 727.505.1423
AEM EMS Tuning, Builds, Assembly, Custom Kits, Installs and more.....
are you spark plugs wet with fuel? if not check for continuity in your fuses and if that doesnt work pull out the injectors and spray it down with carb cleaner. may be clogged. if that doesnt work try and get your hands on a noid light test to see if you injectors are even getting a signal
If you have three quarters, four dimes, and four pennies, you have $1.19. You also have the largest amount of money in coins without being able to make change for a dollar.
The cam angle sensor is working... we have spark.. so that verifies that. The injectors aren't firing at all. I have a test light for the MSD injectors, and there's nothing there. I have verified the 12 volt feed going to them.. and double checked the grounds and resistors. All of that is in order.
Travis
Travis
www.fi-r.net
Nissan Performance
www.fi-r.net
Nissan Performance
we are using an ecu programmed by enthalpy (scott).
...this is so dumb man....im sick to my stomach with all the shit that happens to me...this kind of shit isnt fair. I just really pray to god that everything turns out good and the car runs fine because im on feet right now....I have faith in Travis and Scott so hopefully they can figure this out man......
Norlandt
Norlandt
