Gauge cluster not working
Old Jan 5, 2005 | 11:28 PM
buck19's Avatar
Forever Broke Nissan
Default Gauge cluster not working
nothing works. not even the clock. the clock illuminates, but no numbers, dash light doesnt turn on. head lights work but they dont flip up and down, windshield wipers dont work. im kinda stumped here. this is on a single to twin cam swap. has the twin cam gauge cluster in it.
If you have three quarters, four dimes, and four pennies, you have $1.19. You also have the largest amount of money in coins without being able to make change for a dollar.
Old Jan 7, 2005 | 12:05 PM
buck19's Avatar
any ideas?
Old Jan 8, 2005 | 09:40 AM
RubberBerner's Avatar
Sideways Maffia
try putting the once cam back in if all the fuses are fine...or double check wiring. what harness are you using?
NOBAMA!
Old Jan 8, 2005 | 09:48 AM
buck19's Avatar
the single cam dash harness. thats probably where the problem is. someone told me that you could keep the single cam dash harness. but ill run to the junk yard monday.
Old Jan 9, 2005 | 08:00 AM
G Dragon's Avatar
dude, same thing happened to me, i havent fixed it yet, but when i do ill tell you or something
anti-oval drift association
Team 15!
FUKUOKA JAPAN
Old Jan 9, 2005 | 08:53 AM
Philly Blunt's Avatar
TR Balla Donor Supreme
believe it or not my domelight fuse popped and it did the same thing replaced it and it works..... dont think it will be the same for you tho
Old Jan 10, 2005 | 10:13 AM
buck19's Avatar
ive check the fuses visually. ill check for continuity next time im working on it.
