350Z Tech- Adding Performance
Originally posted by T3T4240
i don't think rims or sway bars are ADDING PERFORMANCE to your car
. Twin turtle that bitch and off you are!
drew
. Twin turtle that bitch and off you are!drew
what ever...
2004 350z Enthusiast:
Custom Stereo
Espirit JDM Body Kit "rear molded"
Nismo Wing
Apexi CAI
Rennen 18 spyder rims
Comming Soon:
Turbonetics singal turbo with forged pistons and internals!
Custom Stereo
Nismo Wing
Apexi CAI
Comming Soon:
I would guess around 4500.00 similar to the SC's.
what about to build the motor up... i am thing aroung 10,000 for every thing....
Custom Stereo
Nismo Wing
Apexi CAI
Comming Soon:
Custom Stereo
Nismo Wing
Apexi CAI
Comming Soon:
I am not sure what the turbokenetics will come with but you will probably need a wideband 02 sensor, if yo uare going to build up the motor I assume more boost so you will need to upgrade the fuel system.
Parts associated with Turbo:
Turbo Kit Assume 4700.00
Fuel System 900.00
Wideband 02 sensor 300.00
Gages 300.00
Total 5200.00
Parts associated with engine build:
Rods 1100.00
Pistons 700.00
Studs 400.00
valve springs & retainers 500.00
Seal kit 200.00
Total 2900.00
Labor (cheaper if you do at the same time)
Removal/Install/engine build/turbo install around 2500.00
Grand Total 10,600.00
That is if you go with stock size pistons, if you go oversized and need to bore out the block and if you want the head reworked then add another 1000.00 or so.
Add miscellaneous stuff and I would budget at least 12k to make sure.
damn thats close enough for me to do in the next 6-8 months....
i went to CFT today and was told on race gas and drag radials or slicks i could get into the 10's easy! i was shocked, they have built a 8's street 350ztt.
i am only looking to get anything over 500rwhp on pump gas... i gonna have to call turbonetics and see if i can get their kit but with a bigger turbo... i want to push between 15-25 lbs of boost
Custom Stereo
Nismo Wing
Apexi CAI
Comming Soon:
Custom Stereo
Nismo Wing
Apexi CAI
Comming Soon:
