CA18 throttle body&maf
Is it true that a ka24de throttle body will fit on a ca18det? also will the ca16de maf and coilpacks work on the ca18? i need options asap....
< < < < < PANDA FINGA!! > > > > >
I believe the TB on the KA is 60mm and the CA is 54mm, the bolt holes can always be drilled and tapped to fit *if they don't already (not sure
)*...its just a simple 3 wire hook up:easy hardwire.
As for the MAF and coilpacks, the OEM Coilpacks for the ca16 and the ca18 (N/A and Turbo models) are all the same...so go ahead if you want. A lot of CA guys put the Z32 or RB maf in instead of the stock one. I know the stock Ca18det MAF is good up to about 14psi...but im not sure about the CA16de MAF...i wanna say its only good till 10-12psi but i can't remember. Sorry.
)*...its just a simple 3 wire hook up:easy hardwire.As for the MAF and coilpacks, the OEM Coilpacks for the ca16 and the ca18 (N/A and Turbo models) are all the same...so go ahead if you want. A lot of CA guys put the Z32 or RB maf in instead of the stock one. I know the stock Ca18det MAF is good up to about 14psi...but im not sure about the CA16de MAF...i wanna say its only good till 10-12psi but i can't remember. Sorry.
NOBAMA!
NOBAMA!
if you do need some sort of tuning then you're sol, because i don't think Anybody tunes CA ECU's... SR may work because they are so similar, i know the KA's will work though. Why not just a CA20 maf???
NOBAMA!
NOBAMA!
sr will probably work, but i decided to keep it stock until I get Microtech, then I can put the KA tb and z32 maf and not worry about my stock ecu.
