Tie Rods?
driveshaft...have someone in it and just put it in gear, you'll be able to see a sever wobble if the slightest thing is wrong, just test drive it after you replace the wheel bearing, and tc rods...no need to diagnose something without a problem.
PS:where'd you order your wheel bearing from? how much?
NOBAMA!
NOBAMA!
Advance/Discount has them for $48.99
http://www.partsamerica.com/SelectPa...aring%2C+Front
I also am waiting a response from www.courtesyparts.com
My Blog: www.HotRodCaddy.com
I would like to thank all of you for your suggestions.
I finally had time tonight (starting my 6 day vacation
) to really get under my car. The wheel bearing that I thought was a little loose, isn't loose at all. When I was doing an in-out mation, I was actually moving the coilover a little. So this got me wondering. I had already visually inspected the front tires, but I went further and found some ODD treadwear on the passenger front tire. I've never seen tread wear like this. So I took RubberBurner's advice and swapped front tires with some stockies, and took her for a ride. That was one hellava smooth ride. Guess I need new front tires. Also still gonna order TC Rods.
Thanks
Charles
) to really get under my car. The wheel bearing that I thought was a little loose, isn't loose at all. When I was doing an in-out mation, I was actually moving the coilover a little. So this got me wondering. I had already visually inspected the front tires, but I went further and found some ODD treadwear on the passenger front tire. I've never seen tread wear like this. So I took RubberBurner's advice and swapped front tires with some stockies, and took her for a ride. That was one hellava smooth ride. Guess I need new front tires. Also still gonna order TC Rods.Thanks
Charles
Originally posted by steve
who ever told you about the drive shaft , i'm not even going to get in to this
the drive shaft will viberate from 0mph to whatevertopspeed mph
but...it's all good
Charles
hey charles, i thought about it earlier...
are you sure that when the prev. owner did the 5 lug conversion that they pressed s14 ball joints into the s13 spindle?
not positive it would cause a vibration, but it certainly wont help.
are these the same front tires that you used at dday5?
that'll be your problem....especially if you're using tires with a lower treadwear rating.
they won't get burnt up like the rears do, but they will wear in strange ways and end up unbalanced
