single cam to dual cam ?'s
Old Dec 12, 2004 | 05:13 PM
stockstang's Avatar
The Pit Stop
Default single cam to dual cam ?'s
OK so I am swapping my 90 S13 single cam motor out for a dual cam. I already picked up a dual cam motor out of an S13. I need to know will my stock engine mounts work, will my stock tranny and clutch work, and do I still have to change the wiring on the ECU?
I still need the following things to finish up:
TB
PS lines
Gauge cluster
Coil
Header
If you have any of these parts let me know. Thanks
-Sage
The Pit Stop
8136016962
Old Dec 12, 2004 | 05:56 PM
hachibill's Avatar
yea sweet lemonade
you need a twin cam engine harness and have it converted to work in your single cam chassis by changing the dash plug. are you looking for an aftermarket header or a stock one? i think i have a coil lying around somewhere too. the stock mounts form either mtor will work and your stock clutch/flywheel/tranny will all work too, its all the same. i'm running a 95 s14 ka in my 90 with power steering and a/c.
Old Dec 12, 2004 | 06:19 PM
stockstang's Avatar
The Pit Stop
Ill take either header just depends on a how good the deal. An aftermarket one would be nice. I'll take that coil if you have one.
I have the skimatics on which wires need to go where so I'll take care of that. I already picked up the harness and ecu with the swap.
The Pit Stop
8136016962
