KA24E weird noise....
Old Dec 11, 2004 | 08:42 PM
Angela's Avatar
That girl with the camera
Default KA24E weird noise....
OK so I get home 2nite offa the interstate and i realise that my engine is clanking like a diesle engine so i turn off the car go inside get a flashlight come out look around nothing unusual so i start it up and try to look for something wrong when its running its just clacking away then it goes away...any ideas would be appriciated i'm LOST
-Jake
[CENTER]
Photography :: AIM :: PicturesSay1word :: Facebook
Old Dec 11, 2004 | 08:45 PM
Slash's Avatar
THE HAMMER
Even though I have no idea, I wish you the best of luck with you E. We are the few.. the proud... the SOHC's...
Hopefully not a rod knock or something. Maybe the fan clutch too, my DOHC fan clutch would make random clanking at times and I had to replace it since it was wearing out.
I dont feel like a sig today.
Old Dec 12, 2004 | 06:00 PM
hachibill's Avatar
yea sweet lemonade
try checking the oil
Old Dec 12, 2004 | 08:56 PM
zeetard's Avatar
It's possible you have a bad knock sensor. Does the noise occur when the engine warms up a bit?
Have you made any changes to the cooling system, timing, or anything else recently?
Old Dec 13, 2004 | 12:02 PM
HaloZ's Avatar
highway whore
i never heard of a DET sensor MAKEING a motor knock. =\
Old Dec 13, 2004 | 01:21 PM
Epstein's Avatar
Retired
hahaha
Old Dec 13, 2004 | 03:30 PM
sentra of attention's Avatar
Jose
maybe you need o adjust ur valves?
Old Dec 13, 2004 | 11:01 PM
truffle_shuffle!'s Avatar
Chomsky with dick jokes!
could be a timeing chain claking.... Happened to my old De////
There are points in life where one looks at his or her situation and says "how the fook did i get here?" ... this is one of those instances....
Old Dec 18, 2004 | 10:35 AM
RubberBerner's Avatar
Sideways Maffia
is it when you're turning? could it be a suspension problem, like a worn ball joint, that clanks a lot. or are you sure that its comming from the engine? could be a chain tensioner- those have a tendancy of staying depressed and the chain slaps against the timing cover. if you can locate a side, or spot on the engine where you hear it the loudest...that would help. Us SOHCerz gotta stay united i just picked up another one...but a dually is goin in that one.
NOBAMA!
