HKS Actuator (for sr20det) questions...
Old Nov 12, 2004 | 04:50 AM
_Charles_'s Avatar
formerly 'RiceRocket'
Question HKS Actuator (for sr20det) questions...
What exactly is the purpose of the HKS Turbo Actuator? and how hard is it to install? Should I do any other mods at the same time (already have walbro fuel pump)?
Charles
My Blog: www.HotRodCaddy.com
Old Nov 12, 2004 | 05:03 AM
Ralph's Avatar
TR Balla Donor Supreme
The purpose of the actuator is to allow you to hold boost alot better than the stock actuator. It usually is set at 11psi(I believe)out of the packet but can be adjusted via screw to increase boost. Doesnt do too much on the stock t25 from what I've heard due to the characteristics that turbo but will do wonders on any aftermarket turbo. You might see a little bit better hold on boost on the t25 but Im not sure.
TR Profile
Myspace Profile
Old Nov 12, 2004 | 05:30 AM
_Charles_'s Avatar
I don't think I even get 11 psi....probably more like 8-9psi. What is the stock psi supposed to be on a BlackTop Sr20det?
Old Nov 12, 2004 | 06:03 AM
dan's Avatar
dan
Get the fuck off my lawn
stock boost on all versions of the RWD sr20 was 7psi.
With most boost controllers, you can run 14 psi (anything more and the t25 starts to blow hot air), but in the higher RPMs, the boost will sometimes fall off to 11 or 12psi, due to the stock wastegate (and sometimes will vary less or worse pending on how good your boost controller is).
Ralph was right about the HKS actuator. for $80 to $100, its not a bad investment, because it allows you to get the most out of your T25, but at 12-14psi your about at the t25's limits (though i have heard you can go 15-16psi with injector/mafs upgrade).
BTW, installation is like 2 bolts, and then the little C clip that holds the actuator arm to the wastegate flapper swivel arm.
charles, i think my brother still has "other" charles' stock actuator that he modified (it has an adj. arm). my brother wanted to sell it for real cheap like $20 or something...i think its set to 11 or 12psi, so if you wanted to try that perhaps.
Old Nov 12, 2004 | 06:09 AM
_Charles_'s Avatar
Actually, I might have adeal on a HKS for $60. That's why I was curious...hate to pass up a good deal.
Old Nov 12, 2004 | 11:28 AM
launch's Avatar
You'll need it!!!
Originally posted by John
not really needed on the stocker if you have a good boost controller, but if you are upgrading turbos anytime soon, a good investment
Better yet and I'm sure John will agree with me if you are going to upgrade later save the money and put it towards an external wastegate.
Brett
Old Nov 12, 2004 | 12:19 PM
Matt Vassallo's Avatar
lifelong learner
stock boost on s13 was 8-9psi ish
stock boost on s14s were like 9-10psi ish
stock boost on s15 was like 12psi
thats why they have boost solenoids from the factory
rest in peace tim.
Old Nov 12, 2004 | 10:59 PM
craig_302's Avatar
boostmonkey
A TurboXS MBC nets me a reliable 14-15 psi every time. Results may vary since my car seems to be an absolute freak of nature for what it is.
