is there a special tool to take out the transmission/differential bolt?
Old Nov 2, 2004 | 06:29 PM
FlipSpeeD's Avatar
Default is there a special tool to take out the transmission/differential bolt?
What size allen tool is used for the transmission and differential bolt? Is there a special tool for this? if so, where can I purchase one? thanks for the input...
Old Nov 2, 2004 | 06:49 PM
osama tim laden's Avatar
kings cannot fall.
uhhhh?
Old Nov 2, 2004 | 07:05 PM
FlipSpeeD's Avatar
sorri bout that, i was referring to the bolts that you have to take out when you're changing the gear/diff oil... grrrrr I'm hoping they're not seized in htere...
Old Nov 2, 2004 | 07:17 PM
Durdan's Avatar
No Ants Drift Member
not an allen
its a 1/2" impact chuck size.
RIP Tim. i miss you, buddy
kings cannot fall.
well, ill just assume this is for a 240.
use a 1/2 ratchet to loosen, and tighten the drainplug, and i usually fill it inside the car, and remove the shifter.
Old Nov 3, 2004 | 12:11 PM
TNathe's Avatar
yeah yeah, i but DO NOT use an impact wrench, easily done like dr. octagon said or you can buy a hand pump for like 5 bucks at Discount to do it from underneath the car and you'll probably need the pump anyways for the diff.
Either way it will be fun and messy.
