Steering Wheel Removal
Old Oct 20, 2004 | 09:23 AM
Evangelion's Avatar
Default Steering Wheel Removal
I've bought 2 brands of steering wheel pullers and none of them seem to fit or work with the Nissan steering wheel. My question is do i really need a puller to remove the steering wheel. I mean it's just one nut in the center. Just curious if there is a way to remove the steering wheel without the puller and without damaging the column. If not anyone know what type of steering puller will work?
Old Oct 20, 2004 | 09:36 AM
buck19's Avatar
Forever Broke Nissan
yep, there is another easier, faster, and cheaper way. i have never used a puller. make sure the wheels are straight forward. after you get the nut off punch the bottom of the steering wheel with the base of your hand pretty hard. if that doesnt work after a couple of hits then try hitting the wheel towards you. it shouldnt be difficult at all. this will knock it loose (you will easily be able to tell its loose) and then you just slide it off after that.
If you have three quarters, four dimes, and four pennies, you have $1.19. You also have the largest amount of money in coins without being able to make change for a dollar.
Old Oct 20, 2004 | 10:02 AM
steve's Avatar
madpom
take that shit back to the store
remove horn you will see a big nut take that off then jiggle the wheel and pull it by hand
5 min max
Old Oct 20, 2004 | 11:49 AM
sil8ty's Avatar
The Hebrew Hammer
just jiggle it+time= wheel off
< < < < < PANDA FINGA!! > > > > >
Old Oct 20, 2004 | 01:17 PM
Evangelion's Avatar
Problem solved. I pulled it with the wheel puller and I pulled it with my hands a second time. Like you said it was easy. I did it 5min after my first post. This thread can be closed or locked now.
Old Oct 20, 2004 | 06:31 PM
sil8ty's Avatar
The Hebrew Hammer
just delete your original post....
