pilot bearing question
Old Oct 8, 2004 | 10:09 AM
buck19's Avatar
Forever Broke Nissan
Default pilot bearing question
if the brass pilot bearing is installed can you see it in plain view or do you have to take something apart. if it is in there then how would i go about getting it out.?
If you have three quarters, four dimes, and four pennies, you have $1.19. You also have the largest amount of money in coins without being able to make change for a dollar.
Old Oct 8, 2004 | 01:09 PM
Epstein's Avatar
Retired
you should be able to see it if you're looking for it. It's sunk in there a little bit, too. Some brave people use a chisel, other's borrow a bushing puller from Autozone, the rest of us just ignore them.
Old Oct 8, 2004 | 01:35 PM
buck19's Avatar
hmmm. i have another to replace it and i kinda want to.
Old Oct 8, 2004 | 01:42 PM
sil8ty's Avatar
The Hebrew Hammer
You can do it, like Epstein said, autozone has a pilot bearing pulling attatchment for a slide hammer.
Its like this: If its accessable, then why not change it? A rear main seal, timing belt, pilot bushing, etc. If you get the chance - do it.
< < < < < PANDA FINGA!! > > > > >
Old Oct 8, 2004 | 01:55 PM
buck19's Avatar
it look like a new rear main cause it was the only thing clean. so i guess the odds are it doesnt have it.
it just doesnt look like itll fit. it seems like if i press it in then the input shaft might not fit.
