triple projector low beam bulb needed
Old Sep 18, 2004 | 10:26 PM
craig_302's Avatar
boostmonkey
Default triple projector low beam bulb needed
Does anyone have a local source? Never have seen a bulb like this before. The bulb in question is a S13 triple projector low beam bulb.
If it is hard to get, I would like a few sets both high and low, as backups. Thank you for any insights ahead of time.
Old Sep 19, 2004 | 09:04 AM
Jeff240sx's Avatar
Cpt. Negative
PM'd.
-Jeff
** This space reserved for someone else's witty quote **
Old Sep 22, 2004 | 08:24 PM
craig_302's Avatar
boostmonkey
For anyone who needs a bulb for their 3 projector low beams, see Jeff. It took a bit of head scratching to decypher the Japanese weirdness in regards to the bulb, but thankfully he had some H1's to plug right into the wonky Japanese adapters.
Bulbs are a little thing, but I am happy now.
Old Sep 23, 2004 | 02:27 AM
Shin180sx's Avatar
FR Pilot
Very few autostores carry H3C. I think discount auto had the last pair when I needed to get bulbs. If you see them, buy them while you can.
Old Sep 23, 2004 | 06:06 AM
Jeff240sx's Avatar
Cpt. Negative
Really. They are H1, same as '97-'98 240s use.
They are not as shown by these H3C.
They are .
The foglights, however, are H3c, as shown above.
-Jeff
Old Sep 23, 2004 | 09:49 AM
steve's Avatar
madpom
ok so it's h1 i need to buy
and is this the same as duel projector
Old Sep 23, 2004 | 08:09 PM
craig_302's Avatar
boostmonkey
Yep...they unplug from the little 3 pronged spring loaded adapter shindig with a little bit of force. Just make sure you remember which way the bulb came out of the adapter...it is sensative to which way it goes in. If it is 180* out, it will not fit and you'll have to unplug the bulb and rotate it. Ah, the things you learn in a dark parking lot.
Old Sep 24, 2004 | 01:57 PM
steve's Avatar
madpom
ok thanks
