Our 500whp Spec V project.. Pics and Info..
Old Sep 18, 2004 | 04:20 PM
TurboS13Hatch's Avatar
Default Our 500whp Spec V project.. Pics and Info..
Hello all..
I am building a SE-R for one of your local guys. I'll post pics, stats and updates here as they become available. This car started out in February of this year with one of our bolt on turbo kits. The car made 270whp and 250ft lbs at 6.5psi of boost on pump gas.
He dropped the car off here, in Louisiana, last week. We'll be building the following..
AEBS Sleeved block
Arias 8.5:1 forged pistons (low silicone content, 4mm higher wrist pin)
Crower custom rods (4mm longer)
AEBS Main and head studs
Metal headgasket
JWT cams
JWT valvesprings
Cryotreated stock crank
KA24DE Nissan OEM rings
Modified oil galleys and drilled Nissan bearings (provides the rod bearings with oil throughout the entire 360* of crank revolution)
Electromotive stand alone system with 3 bar MAP sensor
KA24DE throttle body, and cable/pedal conversion
750cc injectors
Greddy Type R BOV
NX intercooler sprayer
Autometer EGT, Oil pressure and boost guages
Apexi AVC-R boost controller
FI-R custom stainless steel equal length manifold
Garrett GT30R ballbearing turbo
The car also has a ton of other supporting mods.. which are already done. Suspension, 3" exhaust and DP, fuel pump, rail, and everything else needed to make 500whp safely. Here's a few pics..
This is with out bolt on kit.. before any other mods have been done..
AEBS sleeved block and Crower rod/Arias piston
I'll have more pics and updates in the next few weeks..
Travis
www.fi-r.net
Nissan Performance
Old Sep 18, 2004 | 04:26 PM
adero's Avatar
Uber 1337
sweet
Old Sep 18, 2004 | 05:39 PM
schoellnasty's Avatar
Can't wait till this is done so I can see the results. Good luck with the build and I'm very glad to hear that you escaped Ivan with minimal damage there in Louisiana.
Old Sep 19, 2004 | 12:36 AM
We were very lucky... VERY. Most people don't realize how much damage a storm like that could do to Southern Louisiana.
Travis
www.fi-r.net
Nissan Performance
Old Sep 19, 2004 | 11:01 AM
RubberBerner's Avatar
Sideways Maffia
this is going to be sick...will this be the highest HP spec on the streets?
NOBAMA!
Old Sep 19, 2004 | 11:21 AM
lillzilla's Avatar
Fallen from grace~
nice project ....good luck
Old Sep 19, 2004 | 11:32 AM
Blueboost's Avatar
towards antisocial
wow! very nice to see a project like this. I will be watching this thread/project closely.
do you guys have a website, or any other avenue to obtain additional information as it becomes available, or should I just keep tuned to TR?
Old Sep 19, 2004 | 11:44 AM
This will be the highest HP QR that I know of. We hold the record for the highest HP QR right now.. 391whp on pump gas on a Mustang Dyno. That car was built last year.
Our site is www.fi-r.com . However, you can look here for updates.. Since this is Norlandt's home-town forum.
Travis
www.fi-r.net
Nissan Performance
Old Sep 19, 2004 | 12:51 PM
SnowMann's Avatar
TR Shop Mod
also
www.thevboard.com
You should go there more anyway...
SnowMan tuning
Old Sep 19, 2004 | 02:48 PM
Blueboost's Avatar
towards antisocial
Originally posted by SnowMann
also
www.thevboard.com
thanks, yes, I have been meaning to spend more time there. I haven't even had much time to spend with the V itself
