93 sentra Q's
Old Sep 4, 2004 | 07:15 PM
Sneakin Deacon's Avatar
PSSHHH x2
Default 93 sentra Q's
its automatic, and almost positive its a 1.6 (XE) but not sure of the engine code...is it GA16DE? and was there a turbo version of this motor? cant find anything on a DET version but maybe im just not lookin in the right spots. basically just lookin for a manifold, i dont wanna weld one up if there is an oem one available.
El Pendejo Loco
2002 Suzuki Hayabusa
1507 "dry" block
Brocks megaphone
Spencercycle 10" swingarm
MPS auto shifter
Hays convertible clutch
Yea, that about sums it up...
Old Sep 4, 2004 | 07:36 PM
Jap's Avatar
Jap
VTEC Out
No , didnt come turbo in a stock form anywhere .
Better off starting with a SE-R or SE with SR20DE .
Hondata saves lives
Old Sep 4, 2004 | 08:05 PM
PSSHHH x2
screw the sr20 ....and are you sure there was never a ga16det in anything?
im not lookin to dump insane amounts of money in this, i just want like 150whp thats it. only lookin to spend like maybe 400 bucks.
El Pendejo Loco
1507 "dry" block
Brocks megaphone
MPS auto shifter
Old Sep 5, 2004 | 08:57 AM
RubberBerner's Avatar
Sideways Maffia
do a KA fwd conversion...they came with about 150 hp and tq. other than that i've never seen a nice NA Ga16de...i'd say do custom exhaust, intake, advanced timing, P&P head, and other small stuff...not sure if you'll net 150hp, but it will be faster no doubt. Have you thought of a turbo GA? that would be original man.
NOBAMA!
Old Sep 5, 2004 | 10:54 AM
PSSHHH x2
i thought my original post made it clear i had thought about a turbo ga??? i was just lookin for a manifold. i am going to use a 9B off of a 3000gt VR4. so in that case, it will all be custom exhaust, custom intake piping, in no way will i advance the timing, and if i blow a headgasket, then ill P&P my head...ive got a friend with a flow bench so i can keep the flows and velocity relatively close then work from there, and i can enlarge the combustion chamber some to drop compression if need be. but i cant really do anything until i can figure out what size injectors these are, how much the fuel pump flows, how much pressure the injectors can handle, and some other minor little things. probably going to end up running a BTM and FMU and if i need injectors, an SAFC so those would kinda push me to $1000 total
El Pendejo Loco
1507 "dry" block
Brocks megaphone
MPS auto shifter
Old Sep 5, 2004 | 01:41 PM
LockedDownMotorSport's Avatar
Orlando Street King
There is a GA16DET :] People need to do a little more research but the main motors that people swap into the car our the GTi-R motor and the Bluebird.. both motors will give you a 12 sec Sentra.. with simple bolt on mods on the GTi-R motor will get you a 11 sec car.. if you got money to spend you can get it to 500HP+
Old Sep 5, 2004 | 01:56 PM
PSSHHH x2
i dont need 500hp to run 11's...i dont even need 300...and like i said, im not lookin to spend alot...if i try to do a gtir setup, i am going to be coming outta pocket for alot of crap i dont need.
El Pendejo Loco
1507 "dry" block
Brocks megaphone
MPS auto shifter
Old Sep 6, 2004 | 03:05 PM
Boostin97SE-R's Avatar
Resident Asshole
Kenny, there was never an oem ga16det, however there kits for that. http://www.hotshot.com/turbo/NS6020.htm
I thought I used to see cheap turbo manifolds on ebay for that motor. Ill do some more searching around for you.
John
R.I.P Dad.
The greatest man I've ever known.
6/14/43 - 7/11/06 2:24am
Old Sep 6, 2004 | 06:04 PM
Epstein's Avatar
Retired
Someone did an NA build up on a GA16DE. SCC? I think a Hotshot header and some JWT cams are what really wore that motor up.
Old Sep 6, 2004 | 06:17 PM
lillzilla's Avatar
Fallen from grace~
you suck shut up ......screw the sr ?
your $400 budget is like you
champagne tastes on a beer budget
get 93sentra SER motor or a pos altima-ka motor and theres your power goals .
put a pos altima ka .$150......
turbo = better borrow some loot $400
for the bov.smic,manifold,piping ,injectors ect.....
isn't the pulsar gti-r and the bluebird sr motors ?
