LSD help
Old Aug 11, 2004 | 08:15 PM
Sohc4now's Avatar
^^^I'm with stupid
Default LSD help
So i was researching for a LSD for my 240sx and came across the PHANTOM GRIP Limited Slip Differential conversion kits. It's around $250 and they dont tell you if its worth a damn or not. So is it worth it, or should i just go buy a used LSD? And how much do used lsd's go for???
(sorry for all of the questions, but i had to know!!!)
Old Aug 11, 2004 | 08:46 PM
Miles's Avatar
It's a wooden pickle.
Default Re: LSD help
*rolls up magazine*
NO!
*smack*
BAD!
Old Aug 11, 2004 | 10:57 PM
Miles's Avatar
to answer your question, go with a real diff... you'll be much happier... i've heard nothing but bad things about phantom grip...
Old Aug 11, 2004 | 11:00 PM
Jeff240sx's Avatar
Cpt. Negative
Random grip. Period.
-Jeff
** This space reserved for someone else's witty quote **
Old Aug 12, 2004 | 05:42 AM
hachibill's Avatar
yea sweet lemonade
phantom slip. i drove a 240sx with one in it and it pulled a one wheeled peel alot. very unpredictable in what the lsd was doing. sometimes it would work and sometimes it wouldn't. POS.
Old Aug 12, 2004 | 10:51 AM
Sohc4now's Avatar
^^^I'm with stupid
I just dont want to put in a J30 diff cuz it'll really bog down my car and lord knows its slow enough as it is. Is there anyway to get a 240sx lsd from around here without sacrificing my first born?
Old Aug 12, 2004 | 11:10 AM
Jeff240sx's Avatar
Cpt. Negative
Bog down? 6% difference means if you go 0-60 in 6 seconds flat, 6% slow is only 6.34 seconds.
On the bright side, you should gain some fuel economy.
-Jeff
Old Aug 12, 2004 | 03:01 PM
Matt Vassallo's Avatar
lifelong learner
i can re shim the J30 diff to work with your 4.08 gears for the right price.
i won't burn up your ring and pinion gears in the process either
rest in peace tim.
lifelong learner
Taka should be selling a 2 way mecahnical for about 550. you could always get his TOMEI for 750 !!!! MONEY
rest in peace tim.
Old Aug 12, 2004 | 08:21 PM
Regina's Avatar
5 Foot Fury
GET THE TWO WAY MECHANICAL. The end.
My photography.
