egr vavle delete
Old Aug 8, 2004 | 06:13 PM
spoonfed's Avatar
Tha numba one stunna
Default egr vavle delete
Ok I have turned the intraweb upside down looking for an article or how to on deleting my egr valve I know it involves putting a nickle in the fitting and tightening it down to seal the hole but what about removing the egr itself. Also wtf is that thing next to it they are connected by a vacume line.
... content in sig not work friendly
Old Aug 8, 2004 | 06:50 PM
spoonfed's Avatar
do I need to have a custom block-off plate made?
Old Aug 8, 2004 | 06:54 PM
steve's Avatar
madpom
no
have you done this before to any other car
Old Aug 8, 2004 | 06:55 PM
240sxJay's Avatar
Ka24de N/A
Hmm I've read a few post in different forums of people taking off their egr valve? To my understanding it only deals with emissions, which florida doesnt' have any more, is there some sorta benefit? I know once you remove it you have to change your ecu settings when it's done.
Old Aug 8, 2004 | 06:59 PM
spoonfed's Avatar
Originally posted by steve
no
no
Old Aug 8, 2004 | 08:47 PM
dan's Avatar
dan
Get the fuck off my lawn
pic is of a 95 manifold which is obd-1, which is pretty identical to s13 manifolds, minus the scv butterfly assembly (i have yet to look at one of those before).
if you want to delete the WHOLE EGR this is where it goes back in to the manifold. you'll notice the casting of the manifold with the 4 hex allen plugs in the "egr channel" and if you stick your finger in the open manifold near there you can even find the ports where the exhaust gas is injected back into the intake runners.
i have mine totally removed and it wasnt really worth it at all. i noticed some smoothing out when i took it off initially but nothing worth al lthe time and effort i put into it.
if you dont have time to pull your manifold (dont think its easy like a honda ), you can do the cruch nickel plug method on the exhaust manifold and then you can either do a nickel method on the intake side (by taking the recirc pipe off the back of the head), and i did it using some gasket material and a nickel and some RTV silicon. i had to fully remove it because i theorized that when i turbocharged my car, it would not hold during boost situations and would create a leak somehow. on my spare motor i will also have it welded shut.
you can also weld the recirc pipe if you can fit a welder in there...not a great idea...
or you can crimp and bend a few times...like a toothpaste tube if you understand what im getting at. alot of people have done that and it might leak ever so slightly but not enough to realize.
ps - you'll throw codes.
Old Aug 8, 2004 | 09:40 PM
satanshatch's Avatar
Shoe Whore
Some on the board knows how to do it. It was done in my s13 but it does involve the engine being removed on teh count that the plate needs to be welded. and If Im not mistaken sits on teh back side of the engine. (correct me If Im wrong)
why go through all of that ? if your gonna gain a small amount ?
Old Aug 9, 2004 | 10:05 AM
dan's Avatar
dan
Originally posted by Mars_302
Acutally you should really gain anything from an EGR delete except a less cluttered look. EGR only works under cruising, it shuts off at WOT
yup only thing i noticed was a slightly smoother throttle transition while accelerating (not at WOT).
Old Aug 9, 2004 | 10:15 AM
spoonfed's Avatar
hmmm maybe I'll just let it be for now then.
