s13 idle problems
Old Aug 8, 2004 | 05:27 PM
SilvCivOn17s's Avatar
cause the whistle goes...
Default s13 idle problems
my friend just got a 93 240 w/ the stock ka and it's having some idling issues.w/ the a/c off,it stalls right out immediately after its started,but if u have the a/c on,it idles real low(about 500rpm) and it acts like it wants to stall.any comments/suggestions on what u think this may be?thanks alot
R.I.P. Brian Nichols 02/07/1989-11/23/2008
Old Aug 8, 2004 | 06:18 PM
steve's Avatar
madpom
bump the idle up a bit
Old Aug 8, 2004 | 06:26 PM
is that idle adjustment screw located on the throtle body?i kinda looked but couldnt find it
Old Aug 12, 2004 | 07:12 PM
any more suggestions?
Old Aug 12, 2004 | 08:34 PM
Sohc4now's Avatar
^^^I'm with stupid
Make sure you disconnect the TPS before you adjust the idle
Old Aug 13, 2004 | 01:11 PM
Epstein's Avatar
Retired
What I do is disconnect the ~18pin connector right at the throttle body. Then adjust the idle screw located between the firewall and the rear section of the intake manifold. Adjust the screw until it's around 600rpm. Then, plug the connector back together.
