temp allways at zero
thats gotta be it...do you know which sensor actually operates the gauge is it the two wire coolant temp sensor, or the one wire temp sensor next to it...they both have coolant running past them they are about an inch apart...
... content in sig not work friendly
I believe its the one wire that clips onto the temp sensor. Maybe its just corroded or loose.
It was a stant one from advance auto....I called and talked to the service advisor at lokey nissan and he said the thermostat making it read was a coincedence.
Get the FSM,
test for continuity between pin of of brown/white gauge cluster plug and pin of sensor
if that is still no fixing it
replace coolant temp gauge with known good gauge from another cluster
rest in peace tim.
rest in peace tim.
