240 auto to manual
Old Jul 22, 2004 | 03:13 PM
EnZo 240's Avatar
Default 240 auto to manual
if u siwtch the trans in a 96 240 from an auto to a manual would that mess up the car at all or no and how would i go about doin it
Old Jul 22, 2004 | 03:29 PM
China's Avatar
Communist
yes. it will make ur car xplode... if u do it wrong that is. u have to get all of the parts for the transmission, clutch pedal. clutch slave, all the lines, and probably an ecu for a 5spd. there are more parts that u need im sure, check out www.240sx.org and www.freshalloy.com both are real good sources. you may even want to chech out the search function and check if anything was said about this in previous instances here on TR, probably has.
china
Old Jul 22, 2004 | 04:15 PM
steve's Avatar
madpom
look to spend up to $800
Old Jul 22, 2004 | 04:47 PM
Matt Vassallo's Avatar
lifelong learner
If you do it correctly there will be no problems. Don't take shortcuts. Ask Epstein about it.
rest in peace tim.
Old Jul 23, 2004 | 04:39 AM
buck19's Avatar
Forever Broke Nissan
yeah UP TO$800. i spent about $300 for everything including motor and tranny. the auto ecu works just fine. do a search. thi is asked all the time.
if you have the right tools it will only take a few hours.
ps dont forget a tranny flush with the new tranny.
If you have three quarters, four dimes, and four pennies, you have $1.19. You also have the largest amount of money in coins without being able to make change for a dollar.
Old Jul 23, 2004 | 06:07 AM
Epstein's Avatar
Retired
In a 96 with an OBDII ECU, I"m pretty sure you have to have the 5sp ECU. I did it on a 93, so it was very straight forward. Bolt everything together, then wire the starter interlock and the reverse lights. If you're dealing with an S14, I'd recommend you ask Jeff240sx. He has a "how to" on his website.
Old Jul 23, 2004 | 08:07 AM
evlonedb's Avatar
IM THE NEW F-T-W CHAMP!
enzo get an auto first so you dont kill yourself. you need to learn to crawl before you walk.
Evldereckx2 [5:48 PM]: hey if u hook it up with a fatty thats a good excuse to get a sr lol
Ag04 [5:49 PM]: lmao
Ag04 [5:50 PM]: "but daaaaaad.... I need those cams, injectors, and dyno tuning to still get a 12 sec 1/4 with my 250lb g/f in the car!!!
heres your sign!!!! http://www.myspaceisgay.com/
