Need S14 Gas Tank Now!!
Old Jul 16, 2004 | 07:49 AM
agentAndy's Avatar
more class than college
ok some goon told me the rear suspension has to be dropped to remove the gas tank. i dont have the car to look but is this true or is he full of it? the tank should just drop out so to say, right?
Andrew Carroll @ XAT RACING
team v8 in the works. hold one tango.....
hot hot heat in the cup!!!
Old Jul 16, 2004 | 07:56 AM
SILVIA-S14's Avatar
Suck A Turd!
WOW........welcome to the party....
Fuel Tank Replacement on S14??PICS/How to..Holla
Finally the day came for me and few of my GOOD HELPFUL friends to help replace my fuel tank on the S14 as it was leaking fuel. We replaced the soft lines before already and that didn?t solve the problem so the next big thing was it??..BUSTED FUEL TANK?.
We wanted to put it a how to here for some reference as it?s a hard job to do and not a lot of info is available??.YES I SEARCHED?.Shut your yap?j/k?
Here it goes??To all my friends that helped my ass as usual??I thank yah for all your help and sweat on a HOT Saturday.
1) Take off rear stabilizer bar if you have one
2) Take off the subframe?s bolts (8 in all, 4 main and 2 each on the bracket called Member Stay according to RA-4 in the FSM)
3) Disconnect the little hose venting the diff ( I have J30 diff btw)
4) Disconnect the driveshaft as well so the subframe can be dropped all in one piece including the differential. (Use tranny jackstands to help support the rear subframe and your good friends to balance it) IT IS VERY HEAVY SPECIALLY WITH THE DIFF IN IT AS WELL. We disconnected the parking brakes as well at this point since we went up to the driveshaft to take it all out. (its just easier this way)
5) Disconnect the bottom bolt on the shock absorber on both sides. Be careful at this point the subframe is totally loose and heavy and can tilt easily even with having supported tranny jack. Have few friends to help balance the weight as necessary.
6) Lower the tranny jack and have your friends (BUNCH OF THEM) pick it up and put it on the floor.
7) Inspect under the car for any other possible problems while you have a great look at the sorry ass gas tank on the S14?.j/k
Open fuel cap to release any pressure inside the tank. (See FE-3 for a good view)
9) Get someone inside the car and open the access panel and MARK THE LINES FIRST and than disconnect the harness and the lines and pick up the fuel pump and assembly out of tank as well. There should be nothing connected to the body after this is done so when you drop the tank down, no harness or lines or fuel pump can possibly catch it hanging. Disconnect the soft lines on the bottom as well and don?t forget to mark them down there as well as to what they do.
10) Remove the tank protector shield.
11) Now, take off the belts by taking the clip out towards the front of the car and the belts will come loose. Have your friends help support it as its oddly shaped and could be heavy with gas still inside. ( I did not find any drain plug on the tank). Take the other belt off as well by doing the same.
12) Now on the other side, take the bolts off that are holding the belts towards the rear of the car.
13) After both belts are totally off??..Your tank still needs supporting, don?t drop it or bring it down just yet.
14) Have your friends tilt it slightly so that you can get access to the filler cap area from underneath.
15) Loosen the filler cap clamp and take it out of the filler cap.
16) There is one more clamped vent hose (smaller in size than filler cap), take that clamp off and than put the tank on the ground slowly. It is still full of gas and oddly shaped?.DON?T FORGET THAT.
17) Inspect and clean.
1 Reinstall fuel pump into the new tank or fix the leak on your current one ( I replaced mine for a used unit as it way to much work to be dependent upon some epoxy.)
19) Install in the reverse of these steps.
Some tips
1) Have lift and airtools (helps out a lot)
2) Bunch of friends??More the merrier??(I had 6 total including me)
3) Wear safety goggles
4) Wear shoes and comfortable clothes
5) DO NOT SMOKE NEAR THE FUEL TANK AREA?..ITS RAW GAS??.SMOKE AWAY FROM THE AREA.
Imagestation has the pics here???
http://www.imagestation.com/album/?id=4286789209
Thanks to Adrian, Jesse, Jerry, Rob M, Robin (my cuz) for their help and time.
If I forgot anything, please feel free to add it in there and correct me fellas?..
RINKU
EDIT: I also replaced my tranny and diff fluid as its way to easy to do it now.......you should give that a thought yourself.
I also busted a brake line (rear) so i ended up getting a rear set from Adam at XAT (GOD BLESS THEM)
here is the whole thread by me
https://www.tamparacing.com/forums/s...hreadid=156791
ThanKs
RINKU
FOR SALE ITEMS
http://picasaweb.google.com/10373888.../FORSALEITEMS#
1) BRAND NEW XBOX 360 4GB. (Never Opened - Factory Sealed)
2) TI 89 Texas Instruments GRAPHIC CALCULATOR. Barely Used.
3) Dell Vostro 200 DESKTOP Complete PC Package.
Click link above to see PHOTOS & CONTACT INFO.
I am in WESLEY CHAPEL, FL area and can meet locally. SEE ITEM in person before you buy for peace of mind.
Old Jul 16, 2004 | 08:17 AM
agentAndy's Avatar
eeek
Old Jul 16, 2004 | 08:21 AM
agentAndy's Avatar
gonna be burning the midnight beer on this one guys.
but shit when all is said and done i will have a 95 240 for under 3k. holla! the supra is going to be pissed.
Old Jul 16, 2004 | 11:29 AM
SILVIA-S14's Avatar
Suck A Turd!
If you need access to a lift and tools.......Contact Jesse aka Maxtype240 for base access $4/hr for lift and air tools.....Its well worth it for something like this.......believe me......
I be down to help if yah do it over a weekend.....
RinkU
FOR SALE ITEMS
Old Jul 16, 2004 | 02:08 PM
obituary's Avatar
TR OG
Unhappy
yea i just ordered a tank for my s13 $244 http://www.nissan-parts-dealer.com ..had rust in old one
1972 nova ss
89 240 sr20det
2002 chevy 1500 truck
Old Jul 16, 2004 | 02:49 PM
  #17 (permalink)
agentAndy's Avatar
the s13 tank is metal?
Old Jul 16, 2004 | 02:52 PM
  #18 (permalink)
agentAndy's Avatar
has anyone tried to pull the tank out the front? remove the driveshaft, e-brake cable, fuel lines, and anything else in the way. it seems like it will work. if it fails i will have to drop the rear end.
the car is in really good shape for the price i paid(2600) the interior is MINT. only one small dent in the drivers side door. great deal IMO.
Old Jul 16, 2004 | 07:23 PM
  #19 (permalink)
SILVIA-S14's Avatar
Suck A Turd!
Believe me you have to drop the rear subframe.......
RINKU
FOR SALE ITEMS
Old Jul 16, 2004 | 08:41 PM
  #20 (permalink)
agentAndy's Avatar
yes i do
