the little 240 nick-nacks
Old Jun 21, 2004 | 08:38 PM
buck19's Avatar
Forever Broke Nissan
Default the little 240 nick-nacks
okay, ive realized everyone has been having a bunch of little things go wrong in there 240.
so i thought for the newer guys, like me, there should be a compiled list of what you should do before you start modifying the car to make it just about problem free.
things like:
battery corroding the fuses/box and over flow reservoir.
solution: relocate battery and get aftermarket overflow (helps pass tech)
rubber grommet on the brake pedal breaking and brake lights always on.
solution: get a bolt and 2 nuts and replaced the rubber grommet with this (going to do this tomorrow).
check all grounds and fuses for corrosion and breaks. replace if neccesary.
check battery and power/ground cables for corrosion or splices. replace if needed.
get rid of top timing chain guard.
check for abnormal wear on the chain guides/tensioners and check where the plastic guide clips into the metal bracket for breaks (found a broken one in funks ka, could have spelt disaster if the plastic guide broke away from the guide bracket).
check the timing chains for wear and cracks.
get a power steering cooler to prevent future power steering pump failures.
get a fire extinguisher rated for electrical and chemical fires for just in case reasons.
check for worn suspension pieces.
get the motor compression tested.
check oil and fuel pressures.
replace the belts.
please feel free to add on. just thought that this more important to do first than modifying the car cause i know it sucks to have random small problems pop up all the time. im tired of it now. now i want to go through the car, bumper to bumper, to get rid of all the small potential problems. i think this is a better process to upgrading a car now than just jumping into with new expensive stuff thats not really needed yet.
If you have three quarters, four dimes, and four pennies, you have $1.19. You also have the largest amount of money in coins without being able to make change for a dollar.
Old Jun 21, 2004 | 09:06 PM
JonNoH's Avatar
doesnt even lift
I dont remember where I found this but thought it was funny and saved it
kinda has something to do with your post
Why you should buy a Nissan 240sx... (i love S13)
ka24(d)e thin body parts that dent so easily faded windshield wiper switch cigarette lighter that pops out power windows that stop working odometer that gets stuck leaky bushings uneven camber rear defroster that doesnt work clunky steering overheating blown speakers faded seatbelts faded temperature control automatic seatbelts great interior fabric schemes shitty brakes great way of changing headlight bulbs trunk fabric walls that break off dropping a strut bar nut in the rear brake lights burn out leaky injectors leaky windows strange creaking noises awesome moonroof brittle interior cloth leaky injectors spot on the armrest that rubs away power antenna not working nasty shift boot that falls apart people capacity: 2 people and a midget with no legs wonderful black tape that wraps around the body no cup holders bad timing chain guides driver's side rear lean siezed transmission drain/filler plugs
Pollo is the best admin there ever was ever
Old Jun 21, 2004 | 09:19 PM
Jeremy2792's Avatar
FuelSlut.
It was from a post that I started a while back. I'll see if I can bring it up, there were a couple more along with it also. I'll post up the link later.
-Jeremy
"..We don't claim 17,500rpms, we just win!" -Honda;CBR600RR
MySpace
Email: Jeremy_2792@Yahoo.com
AIM: Jeremy2792
Old Jun 21, 2004 | 09:23 PM
Jeremy2792's Avatar
FuelSlut.
https://www.tamparacing.com/forums/s...hreadid=144171
MySpace
AIM: Jeremy2792
Old Jun 22, 2004 | 05:22 AM
Matt Vassallo's Avatar
lifelong learner
lol, was just about to post that..
http://www.sileightymania.com/funstuff/why240sx.asp
posers.
rest in peace tim.
