what does it take to get a sr20det up to 400whp without causing damage
Old Jun 7, 2004 | 02:00 PM
n2ocamry's Avatar
FUCKCAMRY HELLOHACHI
Default what does it take to get a sr20det up to 400whp without causing damage
what does it take to make a sr20det around 400whp?
please post
Old Jun 7, 2004 | 02:12 PM
coolcloo1019's Avatar
Uhhh...
Lots of money...
Tennessee Vols
Old Jun 7, 2004 | 02:38 PM
Matt Vassallo's Avatar
lifelong learner
A trip to Secret Services
rest in peace tim.
Old Jun 7, 2004 | 02:46 PM
SILVIA-S14's Avatar
Suck A Turd!
+ cash to make it happen......
RINKU
FOR SALE ITEMS
http://picasaweb.google.com/10373888.../FORSALEITEMS#
1) BRAND NEW XBOX 360 4GB. (Never Opened - Factory Sealed)
2) TI 89 Texas Instruments GRAPHIC CALCULATOR. Barely Used.
3) Dell Vostro 200 DESKTOP Complete PC Package.
Click link above to see PHOTOS & CONTACT INFO.
I am in WESLEY CHAPEL, FL area and can meet locally. SEE ITEM in person before you buy for peace of mind.
Old Jun 7, 2004 | 02:55 PM
n2ocamry's Avatar
okay wow that helped
the question is refering to
bolt ons
boost controllers
electronic controllers
internals
not trips anywhere
im a one legged man because of iraq but that does not stop me from loving the drift
Old Jun 7, 2004 | 03:20 PM
SILVIA-S14's Avatar
Suck A Turd!
Many ways to do it.......different routes to take.......most of em should agree on following.......
1) z32 mafs
2) bigger turbo
3) bigger injectors 740cc
4) front mount
5) boost controller
6) tuning and dyno time by the RIGHT PROFESSIONAL (this can make worlds' of diference)
7) intake
exhaust
9) Fuel pump
10) Standalone or custom tuned ECU
other stuff to consider
1) greddy intake or similar
2) upgraded radiator/e fans
3) brake upgrade (z32 or other)
4) cams
5) headgasket (metal)
6) exhaust manifold (upgraded turbo will likely require this anyway)
7) lsd
suspension (coilovers or good aftermarket spring/shock combo)
9) BOV
10) Nice upgraded clutch (Spec or ACT)
RINKU
FOR SALE ITEMS
Old Jun 7, 2004 | 03:22 PM
jdk's Avatar
jdk
Non ducor, duco
You can get 400 hp at the crank with properly sized injectors and a big enough turbo/IC.
If I was shooting for that much HP I would prolly start with a build up at the crank though.
Old Jun 7, 2004 | 03:45 PM
Epstein's Avatar
Retired
400 whp is a lot to ask of the stock block for an extended period of time. Lesser setups have definitly killed SR's. I'd add pistons to the list, personally. If you're going stock block, I'd shop around for the cleanest motor you can find.
Old Jun 7, 2004 | 04:43 PM
PoppaSmurf's Avatar
Chowdah-head
400 is alot to ask, im sure if you rode in a 250 whp SR swap you'd be more than willing to rethink your goals, however, a GT25R with a good fmic, fuel injectors, fuel pump, tuning, and the other knick knacks should get ya there
Poppa J. Smurf
Old Jun 7, 2004 | 04:50 PM
Ralph's Avatar
TR Balla Donor Supreme
Oh your damn right, thats the direction I'm heading in. Acutally with a .86 you'll be closer to 400whp on pump gas, .64 you'll have a quicker spool and from what I've been told is so much more desirable to drive...but will put you closer to the 360-380ish range(from what I've read on other peoples setups)running an external wastegate.
TR Profile
Myspace Profile
