why is my car shaking like that?
Old May 20, 2004 | 09:55 PM
Jonas's Avatar
run some tb cleaner through throttle body, play with the iacv so that idle is steady... see if it still tries to drop... ermm if you are sitting at idle... try to lower both windows at the same time and when they are both fully down keep the button pushed for anther 3 seconds... does your idle drop while its being held down??
Jonas
Old May 21, 2004 | 06:29 AM
Shadytrixta1's Avatar
has whippled VTEC
I dont know about his but mine does.and when i put them all the way up and hold it.But it doesnt drop very far.
Old May 22, 2004 | 04:35 PM
Illswyn's Avatar
Eh, holding 2 window switches at the same time, I read in a manual (forget which car) could cause damage (fuse, wiring, not sure where)
Old May 23, 2004 | 08:08 PM
vonrobins's Avatar
love hondas ftw
ha ha ha your cars doing the harlem shake
._________________________
Old May 23, 2004 | 09:45 PM
Jeff240sx's Avatar
Cpt. Negative
/sigh.
Check your fan clutch. As well as water pump (weep holes).
Both of those will only work/do work when the car is heated up, and would cause the idle to drop, and could attribute to shaking.
-Jeff
** This space reserved for someone else's witty quote **
