A/c works when it wants to?
Old Apr 29, 2004 | 06:15 PM
Guado's Avatar
What can Brown do for you
Default A/c works when it wants to?
Another one of those things that "mysteriously" went wrong AFTER i bought the car...kinda like the bent frame underneath, ever seal leaking, PS line etc... after i asked and was told there was no leaks, the car had been checked out underneath all was perfect, frame was straight etc...
buuuuuuuuuuuuuut anyway who's counting...
My A/C decides to work when it wants to. It's like the compressor doesn;t know when to turn on/off. There is freon in there and the compressor does have the right amount of pressure or whatever. Any ideas?
-Eddie
Old Apr 29, 2004 | 06:33 PM
Epstein's Avatar
Retired
Check your AC relay. My brother just finished burning his up because the AC wire frayed and grounded to the compressor.
Old Apr 29, 2004 | 07:06 PM
Guado's Avatar
AC relay, will be checked tomorrow. IF that is it it will be fixed tomorrow! w00t!
-Eddie
Old Apr 30, 2004 | 09:31 AM
Ralph's Avatar
TR Balla Donor Supreme
Your more than likely low on freon/refrigerant. When your low on the cold stuff, your compressor will surge on and off by itself...or the clutch will kick on and off. Just tap a quick discount guage to it, and check the level of refrigertant(sp?). If not that, then could be the relay, clutch is going bad, or a leak....I'd bet its low on the refrig.
TR Profile
Myspace Profile
Old May 1, 2004 | 09:01 PM
Guado's Avatar
checked levels and compressor...all is good. I did not have time to do the relay...hoping that is it.
thanx again Ralph.
-Eddie
