single to twin cam engine swap
Old Apr 18, 2004 | 09:07 AM
steve's Avatar
madpom
Question single to twin cam engine swap
whats involved in the swap i'm guessing
harness
ecu
witch will come with the engine tranny
is that it
Old Apr 18, 2004 | 11:00 AM
China's Avatar
Communist
you also need the gauge cluster too.
china
Old Apr 18, 2004 | 11:54 AM
JapDanny's Avatar
Anti-Flag
Ifyou plan on keeping Power steering you need twin cam PS lines as well .
Fuck the Flag and Fuck you
If your going to post , please fucking think before you start talking out of your ass !
Old Apr 18, 2004 | 12:02 PM
Durdan's Avatar
No Ants Drift Member
twin cam harness
ecu
twin cam power streering lines
twin cam a/c lines and condenser with some custom a/c line work
(to keep a/c)
twin cam intake pipe & MAFS
twin cam tach popped inotyour gauge cluster
RIP Tim. i miss you, buddy
Old Apr 18, 2004 | 01:35 PM
Matt Vassallo's Avatar
lifelong learner
Originally posted by Taylor Durden
twin cam harness
ecu
(to keep a/c)
don't forget the twincam coil and ignitor. you can use the sohc coil and ignitor if you change the plugs over to the single cam style, but its easier just to use the entire twin cam pieces etc.
the sohc power steering lines will work, I ran them on my dohc for a few weeks until they (like every nissan power steering hose from 1992 or older) started leaking like a SOB.
You'll also want to run a twin cam power steering resivoir, it will line up on the correct side of the motor without any problems etc.
The sohc condenser for the A/C will work fine, you will just have to have the line modified for the compressor. it's usually lots cheaper to have a line made than dig up and get a new condesnsor with new seals etc etc etc. Don't forget to replace the drier when you have the system discharged.
That SHOULD do it for ya, you can use either the sohc or dohc B pipe on the header, they are the same.
rest in peace tim.
Old Apr 18, 2004 | 02:15 PM
lifelong learner
and this is what it will look like when you're done
or something close to it
rest in peace tim.
Old Apr 18, 2004 | 04:19 PM
steve's Avatar
madpom
i'll hopefully be useing a 95 plus engine so i won't have to worry about all that coil and ignitor stuff
Old Apr 18, 2004 | 04:45 PM
driftchik's Avatar
Jamesessesess
[taylor durden]
i'd just have to re-qire your harness for the S14 distributor
[/taylor durden]
