SR13 vs SR14
Old Apr 1, 2004 | 07:47 AM
Acidtalons's Avatar
Default SR13 vs SR14
Was looking around on the net at engines for a friend of mine. I noticed the SR20DET s13s run around $1,100 but the S14s run around $2,300.
Are there any advantages to the s14 other than the 15 extra horsepower and possibly less miles on the swap motor?
Also how much boost will these engines handle in stock form?
Vehicle Repair/Maintenance and TIG welding services for hire (steel and Aluminium), PM or IM me
AIM: Acidtalons
Old Apr 1, 2004 | 07:58 AM
Evangelion's Avatar
S14 has the T28 ball bearing turbo. You can boost alittle higher and you get more midrange torque. Of course the engine will have less miles as well.
I would say get the S13, because you can easily surpass the horsepower of an S14 motor with minor modifications and it will cost you less in the long run. Just make sure you get a good motor.
S13 red/black top will hold 14.7psi max on a T25
S14 black top will hold max 18psi (i think) on a T28
I think I've wrapped it up here.
Old Apr 1, 2004 | 08:09 AM
SILVIA-S14's Avatar
Suck A Turd!
S14 also has VVT
S13 is high port design
S14 is low port design..............
I think you covered everything else
RINKU
FOR SALE ITEMS
http://picasaweb.google.com/10373888.../FORSALEITEMS#
1) BRAND NEW XBOX 360 4GB. (Never Opened - Factory Sealed)
2) TI 89 Texas Instruments GRAPHIC CALCULATOR. Barely Used.
3) Dell Vostro 200 DESKTOP Complete PC Package.
Click link above to see PHOTOS & CONTACT INFO.
I am in WESLEY CHAPEL, FL area and can meet locally. SEE ITEM in person before you buy for peace of mind.
Old Apr 1, 2004 | 08:11 AM
SILVIA-S14's Avatar
Suck A Turd!
Also a suggestion...
No matter what motor you go wiht, i suggest you get the clip. Its just a good idea that way....
RINKU
FOR SALE ITEMS
Old Apr 1, 2004 | 08:23 AM
Evangelion's Avatar
Originally posted by SILVIA-S14
S14 also has VVT
RINKU
damn, left that out, thanks for covering the rest.
Old Apr 1, 2004 | 10:14 AM
Enthalpy's Avatar
TR Balla Donor Supreme
if you are looking at getting an $1100 S13 SR you are looking for trouble!!! good complete motorsets / clips cost over twice that. you get what you pay for. there are several people on this board that have tried the piece it together method and when they are all dont they pretty much all say that it was more expensive adn more time consuming than just doing it correctly the first time.
Old Apr 1, 2004 | 03:17 PM
nismo180's Avatar
my cousin did it this way. said it was the biggest pain in the ass ever. like Enthalpy said it will cost you more then a complete motorset/clip in the end
