sr no start
Old Mar 28, 2004 | 09:38 AM
Jonas's Avatar
Default sr no start
ermmm... dahs lights on, fuel pump on, every other electronic... its clicking but not turning over.. all wires to starter are on and tight...any ideas?? i think something is not giving spark but i cant really think right now.. help thanks
Jonas
Old Mar 28, 2004 | 09:44 AM
tkrskyline's Avatar
TR Balla Donor Supreme
by clicking, do you mean not spinning the engine at all, but rather a quick clicking noise. If so the battery does not have enough power or the starter is not getting enough power. Try jumping it or checking your battery terminals and starter connections for loose connections.
Old Mar 28, 2004 | 10:32 AM
AnTman86T's Avatar
S130 love
Starter turning over? If not could either be starter or solenoid. Also check voltage on battery.
Old Mar 28, 2004 | 10:43 AM
Shin180sx's Avatar
FR Pilot
Probably your ignitor chip, my brothers went out and the same things happened.
Old Mar 28, 2004 | 12:24 PM
Matt Vassallo's Avatar
lifelong learner
starter is dead. a bad ignitor will not stop the car from turning over, it will just not spark.
rest in peace tim.
Old Mar 28, 2004 | 12:32 PM
driftchik's Avatar
Jamesessesess
it could be a starter relay, it is located behind the battery, right behind the passenger side headlight, big blue relay with two plugs. Unplug the large grey plug on it, and jumper the wires, then try to start it. If it still doesnt work, then either starters bad, or clutch switch
Old Mar 28, 2004 | 12:38 PM
lifelong learner
if its the cluch switch, the solenoid will not kick.
same goes for the relay. if the relay is dead, the solenoid wont kick
rest in peace tim.
Old Mar 28, 2004 | 01:05 PM
Jonas's Avatar
my bet is on my starter.. iam replacing it now see what happens..
Jonas
Old Mar 28, 2004 | 01:45 PM
Jonas's Avatar
yeah ive always had a problem with starters going bad on me... changed done running thanks for replies...
Jonas
