won't fire!
Old Mar 14, 2004 | 09:20 AM
RubberBerner's Avatar
Sideways Maffia
Unhappy won't fire!
i have fuel...i have spark...but the engine just turns over, no firing of any kind, not even a pop.
I just got some headwork done and took the whole engine out to clean it up a little bit and remove some of the emissions things (EGR, etc...). now its back in all together...but nothin. any ideas?
NOBAMA!
Old Mar 14, 2004 | 09:47 AM
Sideways Maffia
ok, so i've narrowed it down to timing. how can i time a car that isn't running? set to TDC-DONE, what else? im going to buy a timing light right now.
NOBAMA!
Old Mar 14, 2004 | 10:07 AM
Chin's Avatar
MASTER BREWER:HOT TEA
not TDC, 15 degrees advance timing! that might be it.
Old Mar 14, 2004 | 11:01 AM
Sideways Maffia
well im gonna use my new timing light and try to set it to 15 degrees advance...we'll see how this works.
NOBAMA!
Old Mar 15, 2004 | 08:04 AM
StinkyZ's Avatar
I doubt you will be able to time it when its not running. Check your timing belt or whatever the car uses. There should be procedures in your haynes/FSM manual for setting the distributor or CAS or whatever your car uses to its proper position. How do you know you have fuel?
Old Mar 15, 2004 | 05:32 PM
Sideways Maffia
because i have a high HP all motor application, and headwork works wonders on KA's (not an SR). I have the Chilton's but that's not all that much help.
NOBAMA!
Old Mar 15, 2004 | 05:35 PM
Sideways Maffia
the engine turns over, and will fire once or twice, but never sounds like its gonna start.
NOBAMA!
