what else is need for the 5spd swap.
Old Mar 10, 2004 | 01:40 PM
buck19's Avatar
Forever Broke Nissan
Default what else is need for the 5spd swap.
have a
sohc tranny
clutch pedal
master cyl
brake pedal
going to get
clutch/pressure plate
flywheel
and hard lines
brake fluid
what else do i need
how much are all the hardlines that are needed and is there anything that i should do to help/ speed up the process?
If you have three quarters, four dimes, and four pennies, you have $1.19. You also have the largest amount of money in coins without being able to make change for a dollar.
Old Mar 10, 2004 | 02:04 PM
Durdan's Avatar
No Ants Drift Member
heres a complete list
clutch pedal ass'y
clutch master
clutch line
clutch slave
5 speed transmission w/throw out bearing & shifter
pilot bushing
flywheel
clutch ass'y
transmission shim (in between motor and trans)
manual transmission bracket
manual transmission driveshaft
remove metal colar in the end of the crankshaft on the auto motor and install the pilot bushing in its place
then take lower trans harness from automatic and remove the big grey clip that has only two wires (black and brown). cut off this plug and connect the two wires. plug it back inot its home on the relay box (nuetral safety switch)
cut brake pedal in half; dont swap out the whole assembly. its too muchj of a PITA
RIP Tim. i miss you, buddy
Old Mar 10, 2004 | 03:21 PM
buck19's Avatar
clutch pedal ass'y-----have
clutch master----------have
clutch line---------------need
clutch slave-------------prob need
5 speed transmission--have
throw out bearing ------need
shifter --------------------have
pilot bushing-------------need
flywheel ------------------getting
clutch ass'y---------------getting
transmission shim-------need
manual transmission bracket------have
manual transmission driveshaft---have
you are the man taylor
now does it matter exactly where i cut the master cylinder whole
i know there's already a cutout in the mat inside the car. is that accurate enough to just drill where the mat whole is?
Old Mar 11, 2004 | 06:01 AM
Durdan's Avatar
well, if theres a stenciled hole where the master goes, i'd probably say its a pretty gaddamned good acurate place to put it. look under the dash and you'll see where to drill.
Old Mar 11, 2004 | 07:52 AM
PSI240SX's Avatar
Vagina Stretcher
I was told the TPS is different on the auto cars due to the computer needing to see when to downshift. Ever heard that?
Need custom fab work done?? Go see the best there is!!
www.mazworks.com
Old Mar 11, 2004 | 09:16 AM
buck19's Avatar
well its not on the metal its cut out of the rubber stuff. ill prob have to pull the dash and drop the steering column.
Old Mar 11, 2004 | 09:27 AM
Funk's Avatar
techno
if u buy an exedy clutch at clutchcity it comes with a pilot bearing and throw out bearing, and its a 250$ clutch and the guy will cut off AT LEAST 100.. so expect to get it for like 125. and its a good clutch, i use one and i beat the heell out of it
