suspension
hey man,
just trying to help you here. but you need to be more specific about what you want to do with your car. drag, drift, auto-x, road course?? daily driver? the better the info you give us, the better the info we can give you!!
all other peopel reading this thread...if i see a flame the offeding post will be deleted.
thanks,
Scott
Moderator.
thanks,
Scott
Moderator.
Originally posted by naryne
hmm, then a good suspension for a daily driver
-naryne
-naryne
-JAKE
for a daily driver, you could get by with tein s tech springs, maybe a front strut tower brace, and if any of the bushings are bad, replace those, like t/c rod area, tie rod ends, should be suitable for daily driving without being absurdly low. depending on your mileage u might want to pick up some tokico hp struts or kyb gr2s since for street use u wont need adjustability.
that's what I was thinking 'bout doing. Would probably need the struts since my car does have a few miles on it and i heard if you run different spring rates from factory you will kill the factory struts. My intercooler came in today, I can't wait to see that biatch! Should have it mounted for the meet.
I'm going to have to agree with a simple shock and spring set up.
What year is your 240? I would recommend also upgrading the struts along with the springs. Whiteline has great suspension for our cars. I think this is the website http://www.whiteline.com.au/
My photography.
My photography.
i like whitelines just the fact that they are adjustable (which im too lazy to ever do), and you have to get them from PDM and they are 175 per side now, so ur doing 350 for sway bars (even though cusco, tanabe is 400+) but for 230 you can get the ST's they are probably milder for street. sway bars are a user option, but id upgrade if your D brackets are bent (like mine were), or the bushings are going to crap.
