SR start up problem
Well i got the fuel pump issue fuxed...NOW more shiet...
car cranks but doesnt turn over
#1 ecu is plug is plugged in
#2 tried turning crank angle sensor
#3 reset crank angle...set motor at TDC removed crank angle lined up the mating marks and put it back in...still nothing
#4 has spark has fuel for sure
I dunno man....help out a fellow guy here...i switched from Honda's to Nissan's not for headaches like these
so it's getting spark and fuel to all four cylinders??
no start ? the only thing i can possibly think is that the orange wire is not making connection at the gauge cluster plug near the ecu, and it's not setting the timing to ' startup mode '
rest in peace tim.
rest in peace tim.
i think its the coil packs wire which is blue with red stripe i beleive? i ended up forgetting to hook that up and i had the same problems as you... hooked it up and car started right up... ermm check out www.srswap.com and make sure your wiring is all correct
Jonas
Jonas
the weirdest part of it all the car has started b4
