240sx oil and water temp wire hook up
Old Mar 1, 2004 | 09:58 AM
EricsSR20DET's Avatar
Master of All
Default 240sx oil and water temp wire hook up
ok i have a 92 240sx and i have a oil pressure and water temp gauge both mechanical and i want to know where to hook them up to if you could help me let me know
Easy E
Old Mar 1, 2004 | 10:04 AM
Durdan's Avatar
No Ants Drift Member
i do not recommend mechanical gauges. go electric.
the oil pressure sender is next to the oil filter on the side of the motor. your sender would go there
for water temp, there are two water temp sensors on the motor. they are located on the portion of the intake manifold where the upper radiator hose connects. one has two wires. leave it. the other sensor is a single wire sensor. this operates your gauge cluster temp gauge. remove it and install your new sender there. rethreading may be necessary
RIP Tim. i miss you, buddy
Old Mar 1, 2004 | 10:14 AM
Durdan's Avatar
exactly. last thing you need is for that cheesey plastic line to break and not only spray YOU down with oil, but also run your motor dry eventually.
