lighting probs HELP!!!
Ok finally picked up the 240 from my moms house, I was told the motor is shot and would not run, but i get a new battery hook it up and surprising after sitting for about 6-8 months she turns over on the first try. So bonus there, motor running strong as hell.
But now i happen to realize that my cluster, the seat belts, poplights, tail lights, AC switch, and pretty much everything that is sappose to light up was not working so i am like WTF. My moms neighbor came over and took a look at it checked all the fuses all were good. He then started tinkering with the Poplights he had gotten them to come on. He said that the Relay was stuck or something so he proceeded on just poping out the relays but still no good so now the only thing that I got working is the Headlights to come on but i have to leave them in the up position cause they will not flip up and down. Being that this is a Eletrical prob any Ideas as to were to look?
The last owner did have a system and i belive an alarm with was all ripped out
All help would be Appericated. Thanks
most likely a wire was crimped, or torn loose when the systems were ripped out, some faggot stole my system and i've been having electrical problems ever since! Im tryin to re-wire my car, but its a lot more work than i had expected! Hope its not as bad for you!
NOBAMA!
NOBAMA!
alarms are tapped into the parking light circuit which also lights up the iunterior lights. chances are, the wire was just cut, not properly 'removed'
RIP Tim. i miss you, buddy
anyone have a wiring digram that they can post up so i can print it out? i was hoping that there was a manual in the car that i can use but figures naw. any onther Info out there for help. I would at least like to get the tail lights and brake lights back running so i can drive safely dow the road. Also is there like a main power wire that will control everything? tail lights, head lights, brake light, turn signal, hazards Etc etc........
Well prob was solved it was a fuse under the hood pretty odd looking one at that. It was like a Rectangular clip looking thing located by the battery. could not find the part at any store. had to go to the nissa dealership but my boy has the hook up so i lucked up. thanks every one for all the help or ideas
