Classic SE-R, low budget horseees needed
Old Feb 26, 2004 | 02:28 PM
DreamRWDSE-R's Avatar
I Eat Skittles
Default Classic SE-R, low budget horseees needed
Hey guys, not really new to TR, but kinda newb to Nissan Tech. I was curious to know what kinda low budget stuff I can do to squeeze out a few extra horses. Any info is useful. Here's stuff thats already done. Thanx
1994 SE-R
Lowport, I believe. Stock cams.
Jim Wolf Technology ECU
HotShot Header, stock catback and muffler
CAI
Tokicos all around, like that has anything to do with it.
Old, stock clutch.
Edit- Timing is advanced as well
Haven't taken it to the track, but I'm sure I'm in the low 15s if not upper 14s.
Yes, I'm dreaming of a RWD SE-R. It will be mine, after I win the Lotto.
Old Feb 26, 2004 | 02:43 PM
Epstein's Avatar
Retired
advance the timing is good for a few HP. Then, save up for JWT S4 cams.
Chris
Old Feb 26, 2004 | 02:46 PM
I Eat Skittles
Oops, forgot about that. I think it's around 17 degrees now. You could tell by the rough idle.
Old Feb 26, 2004 | 06:47 PM
Boostin97SE-R's Avatar
Resident Asshole
Uh, you shouldn't have a rough idle at 17*. that is actually within factory specs anyway. I noticed the most when I went to 19*. Also, find an intake cam from a 91se-r. it will make a noticable gain and can be had for less than $100. you can also look into a two piece pulley set from UR. those can be found for less than $200. the mods from there on out pretty much get more expensive.
Oh I almost forgot.. Get the es motor mount inserts or the place racing motor mounts. It will help wheelhop alittle and your car will actually feel more responsive. it will vibrate a little more though but you get used to it. It isnt unbearable. goodluck
R.I.P Dad.
The greatest man I've ever known.
6/14/43 - 7/11/06 2:24am
Old Feb 26, 2004 | 06:53 PM
Resident Asshole
forgot to add.. I actually had a place racing cold air intake and took it off in rainy season and I actually ran faster 1/4mile times with the short ram over the complete cold air. I tested this theory twice with the same results. You may want to give it a whirl since its about to be rainy season again.
R.I.P Dad.
Old Feb 26, 2004 | 11:10 PM
I Eat Skittles
Boostin', I'm not too sure if the previous owner didn't already put in the motor mounts, but I don't get wheel hop at all. I know they help put more hp to the ground. Good call on the cams, thats why I mentioned mine were stock.
It's funny how you got the results you did with the short ram, wierd. I'm thinking of goin to SS to get my baby dyno'd, I wanna see what I'm workin with so far, and test your theory.
Wow, I can actually contribute something to TR. Thanks for the input guys.
Old Feb 27, 2004 | 06:15 PM
2wdBlazer's Avatar
Vechicle Whore
Get a catback & S4 cams. I have a CAI, exhaust, Header, timing and a 91 cam. Good for high 14's. You won't break 14's without the exhaust and 91 cam addition. I'd say mid 14's with the S4's.
-Kris
Current Projects:
72 2wd Blazer
2013 BMW X5
2008 Chevy TBSS awd
