brake upgrade?
Old Feb 22, 2004 | 06:35 PM
inikoni's Avatar
Yonaka Hashiri-ma
Default brake upgrade?
i was wondering what is necessary to convert the fron tcailpers on my '90 240 to the 300zxTT calipers. Is it a direct bolt in. I will be mounting them over OEM sized brembo slotted and x-drilled rotors. Thanks
Old Feb 22, 2004 | 08:37 PM
Epstein's Avatar
Retired
To run 300zx brakes, you need the calipers, rotors, conversion brake, lines, and pads. You'll also either need to drill the Z rotor for 4-lug, or convert to 5-lug. Some early '90 NA 300ZX calipers will fit under 91 SE wheels, but the clearance is around 1.5mm! If you use TT calipers, you'll need non-stock wheels.
Here are some pics of the early '90 NA calipers under (very ugly) SE wheels.
http://www.carbonite.org/~epstein/12/DSCF0014.jpg
http://www.carbonite.org/~epstein/12/DSCF0015.jpg
Old Feb 25, 2004 | 06:07 PM
RubberBerner's Avatar
Sideways Maffia
wow...talk about too close for comfort!
NOBAMA!
Old Feb 25, 2004 | 06:10 PM
turkeyspot's Avatar
Go to PDM-racing.com and they have a conversion kit for the 240
