SAFC MAF question
Old Feb 11, 2004 | 07:06 PM
only1.3's Avatar
NO KA24
Default SAFC MAF question
okay i feel like a retard cause i couldnt find this and i know its been said. I just installed my SAFCII since my friend needed my stock SR20det 370's and i had 550's waiting to get put it. i set my fuel to -33% all across the board. but i didnt know what to set my MAF to i set my hotwire 5 in and 5 out but it idles a bit rough so i changed it up to 6 and 6 and it was still a little rough.. if anyone can help me that would be great.
thanks
Josh
Old Feb 12, 2004 | 04:01 AM
Matt Vassallo's Avatar
lifelong learner
z32 maf and 550s is in 2 out 6 - 33%
in 6 out 6 is sr mafs
rest in peace tim.
Old Feb 12, 2004 | 05:46 AM
Enthalpy's Avatar
TR Balla Donor Supreme
agreed. but that is only a baseline. you are going to need to dyno tune that thing to get everything right. the S-AFC does not know the actual response curve of the MAFS, it only multiplies by a set percentage based on maximum airflow of the sensor. this is a common misconception for most people. they hthink that the S-AFC is will exactly compensate for a different MAF...it will not, it simply applies a percentage change to the reading of incomeing voltage from the MAF. for Z32 Maf on S13 SR it multiplies the incoming voltage by roughly 2.05... yet the 2 MAFS have different response curves so things dont work out exactly correct.
Launch can attest to that. we installed a Z32 MAF on his car and we had to do alot of tuning...even on stock injectors, to get the AFR's where they needed to be.
Old Feb 12, 2004 | 09:07 AM
only1.3's Avatar
NO KA24
okay its not really that its off a little. its OFF alot my idle is rough like i shake when i come to a stop. when i press on the gas it doesnt really want me to rev. im going to go buy some sparkplugs and see what happends.
Old Feb 12, 2004 | 10:45 AM
only1.3's Avatar
NO KA24
well the car ran fine like the first 10 miles i drove it. it idled fine didnt backfire. but once i started it up again like 3 hours after those 10 miles it went to shit. i dont think its cause im running super rich. cause i turned my safc to run leaner and it didnt help the idle 1 bit. also once i took out the spark plugs the 1 and 2 look find but 3 and 4 are black.
any ideas? i only threw on the 550's cause my friend needed the 370's for his car to run
well found out the problem them silly little lower orings broke. good thing i have 4 extra's
Old Feb 13, 2004 | 01:06 PM
launch's Avatar
You'll need it!!!
Definitely need to put that thing on the dyno. Big bonus here not only in getting things straightened out so you don't blow the thing up but also your gonna see some HP gains aswell.
Launch
Old Feb 13, 2004 | 01:27 PM
only1.3's Avatar
NO KA24
well the thing is im not getting it tuned untill i get my turbo on and my Maf on . which should be this weekend or next.
Old Feb 13, 2004 | 06:50 PM
launch's Avatar
You'll need it!!!
All I have to say then is drive that thing easy until you get it on the dyno. I put mine on made a change (upgrade) and then went to the dyno to tune the upgrade. I didn't mind paying to dyno twice for the peace of mind in knowing that everything was safe. Much better to pay a little more now than to pay bigtime later. Besides with all of the cars that seceret service has tuned and the fact that Scott did mine both times I have no problem vouching for the advice given to you by Scott.
Launch
Launch It Like It's Unbreakable!!!
Old Feb 16, 2004 | 02:46 AM
Mugen1182's Avatar
Now with more boost!
Im going to SS to get my AFC2 tuned for my CA
04 Corvette
06 350Z - SOLD
