ka24det timing chains
Old Jan 18, 2004 | 01:17 PM
turkeyspot's Avatar
Default ka24det timing chains
Does anyone know what it takes to do timing chains in the ka24det, mine are slapping around. I was wondering if you had to pull the head to do the switch, or if you can get to the chains through the valve cover.
Old Jan 18, 2004 | 01:36 PM
180SX's Avatar
hot... u gotta pull the front cover off... pull the oil pan to do that .. have fun
martin
Old Jan 18, 2004 | 02:31 PM
Jeff240sx's Avatar
Cpt. Negative
Ung. Unbolt engine/tranny mounts, jack up engine, drop oil pan, remove the valvecover, oil pump, water pump. The latter 2 require removing the fan and shroud. It'll be a helluva day's work.
Get a new engine?
-Jeff
** This space reserved for someone else's witty quote **
Old Jan 19, 2004 | 05:11 AM
Durdan's Avatar
No Ants Drift Member
if its just making a shit load of noise, its the plate under the valve cover. remove valve cover and theres a slapper plate held on by two bolts. remove it.
RIP Tim. i miss you, buddy
Old Jan 19, 2004 | 03:49 PM
JapDanny's Avatar
Anti-Flag
This was what was wrong with my motor .
Take it off ASAP . Noise gone no broken motor
Fuck the Flag and Fuck you
If your going to post , please fucking think before you start talking out of your ass !
Old Jan 19, 2004 | 03:58 PM
Garage Battle's Avatar
i wanna go fast
Default Re: ka24det timing chains
as AW11 & taylor said above, the 'chain guard' plate needs to be removed. it is the piece of metal that hangs over the top of the timing chain, between the two cam gears (very obvious once the valve cover is removed).
take the two bolts out, remove the assemly and the bolts. there is no replacement or recall part...just throw it away, do not put the bolts back in. now, if the piece appears to be cracked, broken, incomplete, damaged, hunt around the valvetrain for it. if it is broken, and u cant find the missing chunks, time to take it to a shop, as it could cause MAJOR damage if not destroy the engine.
AW11's was snapped at the base, and basically resting/bouncing on top of the chain...it was caught in time.
lastly, run 15-40/20-50 oil to guarantee a long like KA24DE
Old Jan 21, 2004 | 06:28 PM
turkeyspot's Avatar
ok i got all the parts, and have dissassembled the motor, im ready to put the chains on and i realize the main timing chain was the wrong length, i got a ka24e chain, thanks to Discount. please dont anyone go to the discount on 54 and bruce b. downs, the people there are morons. Right now its 10:30 wed. night if ne one has, or knows where i can pick up a chain tomorrow please call me. (813) 416-1436 my name is Nick. thanks for all the response.
Old Jan 21, 2004 | 06:38 PM
buck19's Avatar
Forever Broke Nissan
i might be able to get you a nissan brand chain tomorrow if we have it in stock. not sure of the price though. might be more than discount even with the discount i get.
i pretty sure if you go back and exchange it by noon theyll have the right chain later that day if they dont already have one in stock.
answer your phone...
If you have three quarters, four dimes, and four pennies, you have $1.19. You also have the largest amount of money in coins without being able to make change for a dollar.
Old Jan 24, 2004 | 07:56 PM
turkeyspot's Avatar
thanks guys i just got a newer motor, and said screw it. F.Y.I. the chain set for the DOHC is $435-$450. Thanks again to the guys at X.A.T. for helping me out with getting a KA.
And if u could tell me again what all i can take out of the emmissions shit, and how to block certain stuff off, thanks
Old Jan 24, 2004 | 08:13 PM
Chin's Avatar
MASTER BREWER:HOT TEA
search for EGR vavle I already did this, if it isnt on the from page try the 2nd one!
