96 OBD2 ECU Diagram
Old Jan 14, 2004 | 02:18 PM
P_Productions's Avatar
They call me "CHAN"
Default 96 OBD2 ECU Diagram
Hello,
I'm trying to install the Apexi Rev/Speed Meter, and I was wondering if anyone knows where to find teh ECU diagram with the wire colors? I know there are instructions on the Apexi website but they don't mentioned which wire colors they, I really want to make sure I tap into the correct wire
Thanks in advance
Hello!
Old Jan 14, 2004 | 03:14 PM
Plopokiller's Avatar
HoHo's
Apexi should have a pdf on their website. This instruction manual shows you the pin outs on the ECU plug. They are Numbered.
http://www.apexi-usa.com/productdocu...speedmeter.pdf
Read pages 4-8 if that doesnt help i can see if i can upload silvia manual with diagram for ecu.
2640lb.
227.5 RWHP
Old Jan 14, 2004 | 03:26 PM
HoHo's
WRONG PAGE! sORRY
2640lb.
227.5 RWHP
Old Jan 14, 2004 | 07:36 PM
They call me "CHAN"
Sall good bro. Is there a difference in teh wiring of the ECU between trhe OBD1 and oBD2, like hondas?
Thanks
Hello!
Old Jan 15, 2004 | 03:14 AM
MaxType 240's Avatar
All Around Maxed
We are talking KA24DE, right?
You need to specify which year the vehicle is. There are wiring differences from the '96 OBDII and 97/98 OBDII.
Here's a '95 ECU pinout for reference:
http://www.240sx.org/faq/articles/95_ecu_pinout.htm
Ings RSpec, Built KA24DET, GT3071R
VR-4 AWD/TT Winter Sled
Old Jan 15, 2004 | 04:58 AM
They call me "CHAN"
Oh.....well I have a 96 OBD2? Is it the same as that 95 ECu Pinout?
Thanks again for all the help
Hello!
Old Jan 15, 2004 | 05:59 AM
All Around Maxed
You'll be OK with that one then. 97/98 cars like to use the 96 ECU and only have to re-pin 3 wires.
It's all easy when you have the right info I have the AVC-R and SAFCII on mine. Solder the wires during install is the only other tip I can give.
Jesse
Old Jan 15, 2004 | 10:23 PM
They call me "CHAN"
Alright cool.
Thanks alot for the advice!
Hello!
Old Jan 17, 2004 | 04:48 AM
Durdan's Avatar
No Ants Drift Member
dude.
blk/wht = ignition power
blk = ground
ylw/red = tach
ylw/grn = speed
pretty universal USDM wiring codes. the throttle signal you may have to use the pinout sheet for b/c all the shielded wires are white at the ecu, so you need to know which one. but other than that, theres your colors
RIP Tim. i miss you, buddy
Old Jan 17, 2004 | 05:57 AM
They call me "CHAN"
Cool. Thanks alot!
Hello!
