ca18det problem
Old Jan 9, 2004 | 05:45 PM
saturn0317's Avatar
boosted sl2
Default ca18det problem
i finished my motor swap today. i took it for a drive. it drive fine until you go into boost. as soon as i get into boost the car starts to break up really bad until it goes back into vacuum.
any suggestions would be appreciated.
thanks
1989 Nissan 240sx(becoming a 180sx) ca18det, walbro, front mount
14.002 @ 98 mph
Old Jan 9, 2004 | 08:51 PM
180SX's Avatar
bring it to the Z-Fever meet tomorrow... I know CA's pretty well
martin
Old Jan 10, 2004 | 03:33 AM
saturn0317's Avatar
boosted sl2
i'll be at work and i don't quite trust it to drive to tampa from brandon just yet.
14.002 @ 98 mph
Old Jan 10, 2004 | 05:09 AM
Durdan's Avatar
No Ants Drift Member
spark plugs
put NGK plugs in it, gap them to 28, not the gap out of the box
RIP Tim. i miss you, buddy
Old Jan 10, 2004 | 05:25 AM
180SX's Avatar
bleee u just dont wanna get into it with CA's Taylor... What MAFS are u using.. ECU number ? Where is the timing set to ? CA's are extremely finicky about timing... Check to make sure your fuel pressure regulator is plugged in... it is one of the three tiny metal lines running between runner # 3 and 4... CA's hate not having that plugged in as well
This was my CA when I had it
martin
Old Jan 10, 2004 | 06:31 AM
saturn0317's Avatar
boosted sl2
martin
i'm using a ca18det mafs, the ecu # is 98, i changed my timing belt before the install and i installed it the same way it cam off(line up the white lines on the belt to the dots on the cam gears and the crank i think was supposed to be lined up on the second notch from the left to the timing tab)
the only thing i see between 3 and 4 is an intake manifold brace. the regulator has its vacuum line attached and the return line is going to the appropriate place.
14.002 @ 98 mph
Old Jan 10, 2004 | 08:34 AM
Garage Battle's Avatar
i wanna go fast
haus more than likely you have a boost leak.
if the car drives fine till some boost comes on, more than likely thats the culprit. with nissan MAF's it accounts for all air in the system....if under boost it starts leaking air out, then you'll start running real rich and it wont work right. my car had a STUBBORN boost leak on the turbo to hotpipe coupler.
if u cant track it down, and it runs fine in vacuum, drive it over to Z Fever and let them take a look at it.
Old Jan 10, 2004 | 06:40 PM
saturn0317's Avatar
boosted sl2
well Al(streetracingonline) came over and found the problem. it runs great now.
thanks for the help guys
14.002 @ 98 mph
Old Jan 11, 2004 | 12:51 AM
Y2JAY's Avatar
wut was it
