Engine Swap Tips??
Old Nov 3, 2003 | 06:55 PM
RubberBerner's Avatar
Sideways Maffia
Question Engine Swap Tips??
Ok, im swapping my SOHC KA for another one with fewer miles and no warped head/block....i know i have to disconnect the tranny, motormounts, wiring harness, and the hoses attached to the engine bay...but should i do anything else, i think i have to take out the radiator, i will just in case...any tips would be helpful
NOBAMA!
Old Nov 3, 2003 | 07:10 PM
Jonas's Avatar
Default Re: Engine Swap Tips??
hrmm shouldnt be too bad man, as for the radiator i dont remember having to take mine out, but i mean if its obviously getting in the way...take it out heh...ermm might want some kind of chiltons manual maybe?? and if theres any other major concerns thats why we have the nissan forum heh good luck
Jonas
Old Nov 3, 2003 | 07:17 PM
Sideways Maffia
thanks jonas, im sure i'll have more questions comming, this is my first non-VW buggie engine swap
NOBAMA!
Old Nov 3, 2003 | 08:38 PM
Durdan's Avatar
No Ants Drift Member
omg.
remove radiator
ac lines
motor mount nuts
wiring
heater hoses
shifter
fluids
driveshaft
exhaust
throttle cable
motor
installation is the opposite of removal
RIP Tim. i miss you, buddy
Old Nov 3, 2003 | 11:34 PM
Matt Vassallo's Avatar
lifelong learner
for an easier time
remove
a/c compresor (it's easier to remove this than lines, especially if its charged )
power steering pump
motor won't come out without power steering pump / lines / some sort disconnected!! don't forget it!
rest in peace tim.
Old Nov 4, 2003 | 10:19 AM
Jonas's Avatar
yeah everything taylor said, and if you have belts that need to be put, check all the hard to reach parts while the motor is out
Jonas
Old Nov 4, 2003 | 11:27 AM
Enthalpy's Avatar
TR Balla Donor Supreme
clutch slave cyl needs to come off tranny
Old Nov 5, 2003 | 06:36 PM
Sideways Maffia
ya'll are great...thanks wizzards
NOBAMA!
Old Nov 6, 2003 | 02:15 PM
lifelong learner
AHAHHAHAHHAHAHHA
not if youre mattback or scott HAHAHA lololoo
good call scott
rest in peace tim.
Old Nov 6, 2003 | 02:45 PM
Charles's Avatar
Senior Member
disconnect all the stuff connected to the motor.........then reconnect it
92' Nissan 240sx
02' Honda VFR Interceptor
08' Tundra
