help w/ s-afc install
Old Oct 11, 2003 | 12:48 PM
TNathe's Avatar
Default help w/ s-afc install
I need help with a reading i'm getting grom my s-afc i just installed on my 240sx. The air flow % is reading a max of 0.5%. I want to know on a non-turboed car what should my readings be? I'm almost positive something is wrong with the reading i'm getting. Please help!
Thanks,
Tyler
Old Oct 12, 2003 | 07:37 AM
180SX's Avatar
yellow white wire (in / out) backwards - obvious
do you have it set to hot wire and do you have your in / out setting under etc menu set correctly ? martin
Old Oct 12, 2003 | 11:32 AM
TNathe's Avatar
yeah, i tried that. apex-i's manual says for my car its hotwire and sensor number 5. those are the settings i have. so under etc > sensor type > hotwire i have the IN as 5 and OUT as 5. This is correct, no?
Old Oct 12, 2003 | 01:13 PM
Matt Vassallo's Avatar
lifelong learner
yes correct
only if you have a dohc mafs
rest in peace tim.
