hks 264 step 2 cams
Old Sep 24, 2003 | 06:42 PM
need240's Avatar
Default hks 264 step 2 cams
when i get my sr, would these cams be worth the 500$, how would the driveability be? rough idle?
also how are ferrea valve spring kit? is there another set better?
i was thinking the hks cams , ferrea valvespring kit , hks r.a.s., arp head studs.
its probebly going to be a long time until i get my sr20det, but just doing my homework
thanks in advance
-aka-
i am the rope around your neck
Old Sep 24, 2003 | 07:24 PM
Slash's Avatar
THE HAMMER
Enthalpy's car idles fine with much larger cams... its all in the tuning.
I dont feel like a sig today.
Old Sep 25, 2003 | 04:09 AM
Enthalpy's Avatar
TR Balla Donor Supreme
sounds like you are on a good path there! your cam/spring/RAS combo would work great. couple that with a ROM tune for maximum gains adn driveability.
Scott
Old Sep 25, 2003 | 05:30 AM
Gary's Avatar
eh
would it be a combination you could put up with in a daily driver?
AIM gwhIIx
Old Sep 25, 2003 | 05:49 AM
Enthalpy's Avatar
yeah.. no problem
Old Sep 25, 2003 | 11:27 AM
Miles's Avatar
It's a wooden pickle.
while we're on the subject of cams here... can anyone explain what each cam is intended for (low end power, top end, midrange torque, etc) or have a link to a page that will explain these things? 250, 256, 264, whatever. those numbers mean nothing to me... i'm lost. thanks
Old Sep 25, 2003 | 12:24 PM
Enthalpy's Avatar
240-280 are representative of the duration of the cam in degrees of crank rotation. duration meaning the time the valve is open. the higher the number the high in the RPM band the cam will make it's peak power. example
264 generally peak around 6200-6500 RPM
272 generally peak around 7200-7500 RPM
stock cam is a 240 degree.....
Old Sep 25, 2003 | 02:42 PM
need240's Avatar
thanks for the input guys , many more questions to come before i build the beast, and it will be a beast, i'll save the other questions for later. thanks again
aka
