Nismo mount installation
Old Aug 20, 2003 | 12:00 PM
240Nismo's Avatar
Sex for hire
Default Nismo mount installation
Ok, I got the car jacked up, and the motor jacked out of the car. I also have the passenger side motor mount off, and the drivers side loose (bolts off). But I cant get the new nismo mount on the right side! what is the problem?
SUBLIME.
Old Aug 20, 2003 | 07:49 PM
Matt Vassallo's Avatar
lifelong learner
you're not trying hard enough?
rest in peace tim.
Old Aug 21, 2003 | 10:15 AM
240Nismo's Avatar
Sex for hire
i jacked the engine up till the valve cover hit the fire wall...and there still wasn't enough room for the moung to fit in....i'll try for another 2 hours today i guess...
SUBLIME.
Old Aug 21, 2003 | 11:08 AM
SAFKO's Avatar
Light Bulb With Horns
the nismo mounts make the engine sit a little higher. you should not have much trouble, it is a pretty strait forward job.
wut?
Old Aug 21, 2003 | 03:39 PM
240Nismo's Avatar
Sex for hire
Yea i've done them on my buddy's S14, but mine must be retarded or something...
SUBLIME.
Old Aug 23, 2003 | 01:05 PM
240Nismo's Avatar
Sex for hire
its the crew cab, i was plannin on bring my 240 tho.
SUBLIME.
Old Aug 26, 2003 | 02:24 PM
Greaser's Avatar
i had to pull up on the bolt for the motor mount so that it could slide into the hole on the mount bracket on the block. i used a slotted ruller to grab the threaded section of the mount and pull it up ever so slightly and then slide it into the bolt hole for the mount on the block and then lower the motor.
$#@% a mandrel bend. JDM WELD IT!
VA resident invading your boards....wassup to my florida peeps.
Old Aug 26, 2003 | 06:22 PM
240Nismo's Avatar
Sex for hire
thanks guys, i figured it out.
SUBLIME.
