S13 camschaft into a S14
Old Aug 19, 2003 | 04:52 PM
Black240SX_03's Avatar
Default S13 camschaft into a S14
I need to know what parts I need to swap a set of S13 camshafts into a S14 or are they a a straight bolt on application. I've already checked the search engine and couldn't find anything on this topic and I'm still awaitng a response on freshalloy. Thanks!
WTF............
Old Aug 19, 2003 | 05:33 PM
dan's Avatar
dan
Get the fuck off my lawn
depends what camshafts you are using. if you are swapping stock ones in from an s13, its basically taking the old ones out and putting the new (older) ones in. an FSM is definately handy for torque specs. talk to mattback he has a step by step online manual for installing JWT cams, and everything is basically the same for other camshafts. its relatively simple if u take your time and dont half ass and use correct methods to take off the journal bearing caps and tighten to correct specs as per fsm or provided manual.
Old Aug 19, 2003 | 05:50 PM
Yes I plan to go to dyno/bbq/meet. I also will be using stock cams from a S13.
WTF............
Old Aug 19, 2003 | 06:34 PM
Plopokiller's Avatar
HoHo's
Whats so big about XAT?
2640lb.
227.5 RWHP
Old Aug 19, 2003 | 07:03 PM
Matt Vassallo's Avatar
lifelong learner
hahaha doing cams on a ka24de
you better know wyhat youre doing theres a whole cam of worms in there not to mention you probably have to order shims.
but you already knew that
rest in peace tim.
Old Aug 20, 2003 | 07:36 AM
Black240SX's Avatar
I spoke with Courtesy Nissan yesterday and they told me that they don't sell the shims. I plan on buying new camshafts as well. Hey, Mattback,if I get the camshafts can you put them in for me and how much will it cost approximately?
Plop, plop, fizz, fizz, oh what a relief it is!!!!!!!
Old Aug 20, 2003 | 09:48 AM
dan's Avatar
dan
JWT sells shims, and apparently you usually dont have to when installing jwt cams as they are made to comply and its rare to use shims. using stock ones i dunno. matt says you will, but you wont even know whether you need shims til you have the new cams in and measure the tolerances with a feeler gauge. kinda of a PITA.
Old Aug 20, 2003 | 07:50 PM
lifelong learner
private message me if you need to speak to me
rest in peace tim.
