electric fan question
Old Aug 8, 2003 | 08:31 AM
zenki_s14's Avatar
Default electric fan question
anyone know how to hook up the stock electric fan so that it'll run all the time or when u click your key over twice...
Old Aug 8, 2003 | 08:38 AM
gritt's Avatar
Fuckelberry Hound
you have to find a key on source under your hood and hook it to that, or you could hook it up to a switch/relay that you could hit inside.. the first would work best if you had a circuit you don`t use (headlight washers for example) and tape into the circuit. that way you arn`t overloading the circuit. does that help or did you want to know excactly where to hook into?
SHIFT_old school
399.5 hp 430 tq on 95k mile junkyard motor
12.0 @ 118.22 1.89 60`
DILLIGAF?
Old Aug 8, 2003 | 08:44 AM
zenki_s14's Avatar
that helps a bit...i juss needa get under the hood and familarize my self with a few more things...
Old Aug 8, 2003 | 08:45 AM
sil8ty's Avatar
The Hebrew Hammer
all you have to do is find the ground pin for the relay and run it to a toggle switch where you can complete the ground whenever you want. turn fans on, turn them off. plus they retain the pre-set temp setting... check wiring schematics...
< < < < < PANDA FINGA!! > > > > >
Old Aug 8, 2003 | 08:50 AM
zenki_s14's Avatar
check wiring schematics... ???
Old Aug 8, 2003 | 08:53 AM
gritt's Avatar
Fuckelberry Hound
sil8ty`s way will work even better, why do you want to have control of them anyways? forget and leave them one night and kill your batt....are you overheating? what is the problem you are trying to solve?
SHIFT_old school
DILLIGAF?
Old Aug 8, 2003 | 09:00 AM
SILVIA-S14's Avatar
Suck A Turd!
I have the Flex a lite dual electric fans. The control unit it comes with is a POS. So i finally tossed it. I am running the fans with a switch with a light on which tells me for sure that fans are running.
Another good thing is that it can be controlled manually, so if i want, i can turn them on after a bit like in winters when it takes the motor to warm up. Without fans being on with ignition, motor will warm up faster. Than i can flip the switch to on and be on my merry way.
When i overheat, i can turn off the motor and still leave the fan on....(Nice for emergency situations)
Only downfall is if you leave you fans on by accident, your battery will be toast. But that is not possible as the fans are loud, you'll hear em on when you get out of the car or the light on the toggle switch should tell you that when you are in the car.
I am just glad i got rid of the stupid control unit which was a pos.
I just did this, i know what to get and everything, shoot me an email and i'll walk you through
RINKU
FOR SALE ITEMS
http://picasaweb.google.com/10373888.../FORSALEITEMS#
1) BRAND NEW XBOX 360 4GB. (Never Opened - Factory Sealed)
2) TI 89 Texas Instruments GRAPHIC CALCULATOR. Barely Used.
3) Dell Vostro 200 DESKTOP Complete PC Package.
Click link above to see PHOTOS & CONTACT INFO.
I am in WESLEY CHAPEL, FL area and can meet locally. SEE ITEM in person before you buy for peace of mind.
Old Aug 8, 2003 | 10:10 AM
zenki_s14's Avatar
just a way to let me car cool faster when i let it rest when ever i go drifting...
Old Aug 8, 2003 | 11:28 AM
sil8ty's Avatar
The Hebrew Hammer
definately, and since youre only completing the ground that the computer does (at the right temperature) you're not running a direct bypass - therefore they only come on if the ignition is on... When you shut the car off, the power to the circuit for the fans cuts.
Old Aug 8, 2003 | 12:27 PM
zenki_s14's Avatar
kool thanks for the help
