Does anyone know why I have NO FUEL PRESSURE?!?
Ok so I was driving down the street last night and I made a U turn in second, my car hesitated as it so often does, because it needs tuning. after the hesitation it revved up to 4 grand then it died engine still running and everything absolutely 0 fuel pressure. Does anyone have any clue why this would happen? I am hoping it is something electrical. I have a walbro pump that is less than a month old. Please give me some suggestions before I drop my tank.
When u turn on the key can you even hear the pump running at the tank? (btw I know nothing specific to your car, just cars in general)
Assuming its an electric pump in the tank, you should be able to hear it running, right?
Offroading Spots near Tampa
Green markers = Pay spots
Blue markers = safe free spots
Red markers = not so safe free spots (possible trespass issues)
Does it crank when you try to start it now? do you hear the fuel pump clicking? Check you fuse for the fuel pump....
Run diagnostics on your ecu and get the codes?
That's it for now.....let us know what you find out
RINKU
RINKU
FOR SALE ITEMS
http://picasaweb.google.com/10373888.../FORSALEITEMS#
1) BRAND NEW XBOX 360 4GB. (Never Opened - Factory Sealed)
2) TI 89 Texas Instruments GRAPHIC CALCULATOR. Barely Used.
3) Dell Vostro 200 DESKTOP Complete PC Package.
Click link above to see PHOTOS & CONTACT INFO.
I am in WESLEY CHAPEL, FL area and can meet locally. SEE ITEM in person before you buy for peace of mind.
FOR SALE ITEMS
well if you cant hear the fuel pump turn on for a sec when you turn the key to ignition than it is not turning on. check your fuses and wiring for the fuel pump relay(it is a black wire with a pink stripe) located in the battery area. other than that you just have to start trouble shooting things.
wut?
wut?
look at all of you connections at the fuel pump. you might just have a loose negative or something of that matter.
If you have three quarters, four dimes, and four pennies, you have $1.19. You also have the largest amount of money in coins without being able to make change for a dollar.
Ok I am getting pissed. the pump is getting power but I don't think it would be bad since it has only been in use for a few weeks. Is there anyone who can help me out on this one. Or anyone that would be willing to take a look at it. I live in palm harbor and the car isn't going anywhere so I can't take it somewhere. Help a brother out. Thanks
use a voltmeter and check the current from your + and - on the fuel pump.
