Need major help!
Old Jul 17, 2003 | 05:58 AM
KatieBang's Avatar
I'ma get that hula hoop!
Unhappy Need major help!
Ok..so I was leaving my house to go to work..My car started fine..had a little trouble getting it out of first gear but when I went to put it in reverse...it won't move!
My clutch pedal was all the way in and everything and I'm stuck in neutral.
Can someone tell me what this might be? The clutch pedal feels a little weird, but hell, what do I know?
Thanks in advance
Old Jul 17, 2003 | 06:29 AM
BumpinPSI's Avatar
Eye Heart Nissan
sounds like a bad slave cylinder.
Tampa Bay Lightning - 2004 Stanley Cup Champions
Old Jul 17, 2003 | 06:41 AM
KatieBang's Avatar
Clutch isn't hard or soft..doesn't make any noises.
To me...it just seems like the clutch pedal isn't all the way out when you're not touching it..but then again, I've been playing with it so who knows if it's my imagination or not.
Car runs great, I'm just stuck in neutral
Old Jul 17, 2003 | 06:49 AM
sil8ty's Avatar
The Hebrew Hammer
slave may be stuck, or cluch fluid... one or the other.
< < < < < PANDA FINGA!! > > > > >
Old Jul 17, 2003 | 07:09 AM
KatieBang's Avatar
Ok...so I had someone come and check it out and play with it and I was told possibly the pressure plate or the linkage?
Anything sound familar to your guys? He got in and played with it and got it into pretty much each gear, just had a hell of a time with it.
Old Jul 17, 2003 | 07:53 AM
BumpinPSI's Avatar
Eye Heart Nissan
omg.
dont worry about your linkage
it's fine
Old Jul 17, 2003 | 08:25 AM
dsonik1's Avatar
Professional Drif-Tater..
htrow out bearing, maybe? Nissans are notorious for being a bithc in reverse (you sometime have to shift to first and then into reverse).... other than that... I'd have to see it.
Doogie: "Hey did you notice I was tandem with you slidin around that corner?!"
Sonik: " Cool! Did it look hot?, cause if you ever get that close to f'ckin my car up again.... the fuzzy balls hangin from my mirror will be yours
Import Corner Inc.
6432 massachusetts ave
new port richey,fl 34653
1-888-520-9601
GO TO:www.importcornerinc.com
MYSPACE
www.myspace.com/bmwsonik
Old Jul 17, 2003 | 08:56 AM
KatieBang's Avatar
Originally posted by BumpinPSI
omg.
it's fine
but i still can't move my car
